    How to join an especific discord channel
    2.3k
    • Roberto LuisR
      Roberto Luis
      I was trying to find a way to do this and didn't find an especific solution for it, but I saw a script that could execute some keyboards commands. In fact, u can navigate on discord using just your keyboard, I mapped a bunch of commands that could help me join an especific channel but IDK how to transfer it to a script.
      // I know that it's kinda amateur but thats the way that I found it lmao
      Tab //start the navigation on discord using the keyboard
      down arrow x10 times //going down to find the correct server to join (particular value)
      press enter //to open the server
      press tab x9 times //to start navigating on the channels
      down arrow x9 times //to select the correct voice channel
      press enter //to join it
      I wonder If someone could transfer it to an VBSscript and help me to use it on TriggerCMD
      Roberto LuisR 1 Reply Last reply Reply Quote 0
      • Roberto LuisR
        Roberto Luis @Roberto Luis
        @roberto-luis I Did it! I made a script using Autohotkey that can find the server and click on it searching for the correct color. Then, the script clicks on it and does the keyboards' commands to join the correct channel
          Russ @Roberto Luis
          @roberto-luis , nice job! Would you mind posting your script here?
          • Roberto LuisR
            Roberto Luis @Russ
            @russ In fact i'm having some problems to run the script .ahk with the triggercmd, when i do it manually, it works very well, but when I copy and paste the script's target and ask triggercmd to do it, it doesn't work.
            Could u help me with it?
            Then I can share the entire project working here
              Russ @Roberto Luis
              @roberto-luis, can you show me your command?
              This works for me because of where autohotkey is installed on my PC, and where my script is.
              "C:\Program Files\AutoHotkey\AutoHotkey.exe" C:\autohotkeyscripts\media.ahk mute
              That mute at the end is a parameter for my script.
              • Roberto LuisR
                Roberto Luis @Russ
                It returns me this message when I try to turn my .ahk archive onto .exe
                It says successfully compiled, but no new archive is created. Then I tried to put the content of the message on the triggercmd's command, but nothing is happening
                  Russ @Roberto Luis
                  @roberto-luis, if you rename that ToTalk.exe in the folder in the background, does it recreate a ToTalk.exe when you compile it again?
                  Also, you don't have to use a compiled version. You could use a command like mine above.
                  • Roberto LuisR
                    Roberto Luis @Russ
                    Not at all, it continues just "ToTalk.exe.ahk"
                    • Roberto LuisR
                      @roberto-luis It worked!
                      IDK what changed, but with this name the triggercmd could start my script.
                      #SingleInstance Force
                      CoordMode, Pixel, Screen
                      CoordMode, Mouse, Screen
                      Loop
                          PixelSearch, x, y, 1925, 11, 1994, 201, 0x7EDB32,, Fast
                          if (ErrorLevel = 0)
                              MouseMove, %x%, %y%
                              break
                      Click, Left
                      Loop 10
                      	Send, {Tab}
                      	Sleep, 300
                      Loop 8
                          Send, {Down}
                          Sleep, 300
                      Send, {Enter}
                      Here u are the code, just need to change the pixel that u wanna search to click first (Pixel of the discord server's icon)
                      RussR Roberto LuisR 2 Replies Last reply Reply Quote 0
                        Russ @Roberto Luis
                        @roberto-luis, awesome. Nice job.
                        • Roberto LuisR
                          @Russ Thx for the help
                            Russ @Roberto Luis
                            @roberto-luis, np. Any time.
