    How can I change spotify device?
    spotify
    2.1k
    • Gaston MardonesG
      Gaston Mardones
      When you tell google home: play spotify, it plays it on the speaker of the same google home. I would like to know if there is any way to change the playback device through some script or something.
      I saw this post: https://www.triggercmd.com/forum/topic/134/switch-spotify-devices-with-alexa-and-smartthings
      In which, through a VBS script, he managed to change them, but in the script he used
      WshShell.SendKeys '^ {d}'
      That line means ctrl + c, which was a shortcut for the switch device button.
      But unfortunately that shortcut no longer exists, at least in my version of Spotify on Windows 10.
      If anyone knows any solution, I wait for it, thanks.
        Russ @Gaston Mardones
        @Gaston-Mardones, when I open the Spotify Music app in my Windows 10 PC, then press CTRL-D, it brings up the output device screen, then if I hit tab a few times to select a device, then press Enter on that device it switches to it.
        So you could make a script that does that. You could use a .vbs script like that article shows, or you might have better luck with AutoIT.
        • Gaston MardonesG
          Gaston Mardones
          Thanks for the answer, but that is precisely my problem, that in my spotify application in windows 10 the shortcut ctrl + D does not work. So I wanted to know if there was any other solution.
          For now I made a Python script that opens spotify in the web browser and hit TAB 24 times and ENTER until it opens which should do ctrl + D. But as you can imagine, it depends on the page loading fast, and more variables.
          Just in case, sorry for my English, I'm from Argentina and I do what I can haha
          Thanks again
          RussR Marcos Martinez DebelluitM 2 Replies Last reply Reply Quote 0
            @Gaston-Mardones, I see now. That's odd - I wonder why CTRL-D doesn't work. Instead, you could simulate a mouse click instead using AutoIT like this:
            https://www.triggercmd.com/forum/topic/763/start-netflix-app/21
            • Marcos Martinez DebelluitM
              Marcos Martinez Debelluit @Gaston Mardones
              @Gaston-Mardones Buenas! Alguna solucion nueva para cambiar de dispositvo en Spotify? Gracias!
                Russ @Marcos Martinez Debelluit
                @Marcos-Martinez-Debelluit, this is one method. I used the SoundVolumeView.exe tool from Nirsoft.
                SoundVolumeView.exe /SetDefault "Realtek*\Device\Speakers\Render" all
                SoundVolumeView.exe /SetDefault "*USB Audio Device\Device\Speakers\Render" all
                If I run the above commands while Spotify was playing a tune, it switches my computer's audio output from between my "3- USB Audio Device" (usb headphones) and "Realtek High Definition Audio" (speakers).
                Notice I shortened the device names that the GUI showed me using the * wildcard.
                I have Spotify set to "This Computer".
