Launch a website
9.6k
  • R
    {"trigger":"TRIGGERcmd site","command":"start http://www.triggercmd.com","ground":"foreground","voice":"site"},
    • L
      Lucas Hortale
      Can i lauch 2 or more websites in the same trigger?
      R 1 Reply Last reply Nov 27, 2020, 4:49 PM Reply Quote 1
      • R
        Russ @Lucas Hortale
        @Lucas-Hortale, sure. You can run many commands if you create a script, and have your command run the script:
        Assuming you're on Windows you could make a c:\tools\websites.bat script with these contents:
        start https://www.triggercmd.com
        start https://www.google.com
        Then make this command: c:\tools\websites.bat
        Or, if you want to be lazy you could use a & between two commands like this:
        • J
          Julio Maradiaga
          Is it possible after the site is open to send a key stroke or command?
          B 1 Reply Last reply Apr 13, 2021, 7:36 PM Reply Quote 0
          • B
            Brole @Julio Maradiaga
            @Julio-Maradiaga check out autoIT
            1 Reply Last reply Reply Quote -1
            • D
              Djaman Barbosa
              Is it possible to open a webpage in a specific browser? And open the webpage in a new window?
              R 1 Reply Last reply Nov 13, 2021, 4:44 PM Reply Quote 0
              • R
                Russ @Djaman Barbosa
                @Djaman-Barbosa , if you want to launch Chrome or Chromium from with a new window, add --new-window like this:
                "C:\Program Files (x86)\Google\Chrome\Application\chrome.exe" --new-window https://triggercmd.com
                This works with Edge too because it's Chromium based.
                "C:\Program Files (x86)\Microsoft\Edge\Application\msedge.exe" --profile-directory=Default --new-window https://triggercmd.com
                I found that here:
                https://peter.sh/experiments/chromium-command-line-switches/
                • S
                  Smart Communities
                  @Russ said in Launch a website:
                  Anyone know how to open a URL in the existing tab?
                  I have a URL running full screen. When using the start command it opens the URL but the old one is still running and I can hear it's audio.
                  R 1 Reply Last reply Dec 6, 2022, 9:28 PM Reply Quote 0
                  • R
                    Russ @Smart Communities
                    @Smart-Communities, you could use a script that kills the browser then relaunches it with your new URL.
                    S 1 Reply Last reply Dec 6, 2022, 9:38 PM Reply Quote 0
                    • S
                      Smart Communities @Russ
                      @Russ That's what I ended up going with. One script & trigger to initiate and another one in the reverse. Thanks
