    Unable to access to the aplication
    Instructions
    3.8k
    • G
      gabi92a
      Hello, im currenty stucked in the sign in page. I cant enter and its not showing to me any error.
      GIF: https://gyazo.com/e119697d037440eb8ae8d605067ebb65
      My regional configuration is Spanish.
      Regards and thanks in advance.
        Russ @gabi92a
        @gabi92a, that's a nice way to show me the problem.
        Can you copy/paste your debug.log file into this thread? Here's how:
        Animated GIF: https://gyazo.com/61a6e5ac0b20c5e8b0822ae90d62cdf7
        Type this into the Open field: %userprofile%.triggercmddata\debug.log
        Also in the meantime, here are some things to try:
        • Reboot
        • Turn off Antivirus temporarily
        • Try it on a different computer
        • G
          gabi92a
          Attempting to log in with token
          (token removed)
          Token login failed.
          Im a software developer, so i know the importance of communicate correctly the bug.
          I did the step 1 and 2, but i dont think that this is the problem. Try it on a different computer is not a option, and i have a good one.
          I'm using the token of here: https://www.triggercmd.com/user/computer/create
          Any ideas?
          Regards.
          • G
            gabi92a
            Is happening the same here: https://www.triggercmd.com/forum/topic/420/agente-de-windows-en-el-sign-in-no-funciona
              Russ @gabi92a
              @gabi92a, what country are you in?
              I wonder if there's some sort of firewall or proxy server between your computer and the TRIGGERcmd servers that's preventing the token login.
              It's strange though because I looked at the code and it's a pretty straight forward request:
              function tokenLogin(token,callback) {
                // Configure the request
                headers.Authorization = 'Bearer ' + token;
                options.headers = headers;
                options.url = urlprefix + '/api/command/list';
                options.method = 'GET';
                // Start the request
                request(options, function (error, response, body) {
                  if (!error && response.statusCode == 200) {
                    writeNewTokenToFile(token);
                    callback(token);
                  } else {
                    console.log('Token login failed.');
              I tried your token and it worked for me - it created a computer in your account. I deleted it afterward.
              Also, I removed your token from your post so other people can't create computers in your account, or trigger your commands once you get this working.
              • G
                gabi92a
                Im in Spain, Barcelona. I added the application to the firewall rules, but is making the connection in port 80 right?
                • G
                  gabi92a
                  I will try to using a vpn or something like that, and lets see if i have differences with another range of ip
                    Russ @gabi92a
                    @gabi92a, good luck. Do you know if Spain has some sort of country wide firewall? Like China? I doubt it, but I thought I'd ask.
                    Also, the agent connects to https://www.triggercmd.com over port 443.
                    • G
                      gabi92a
                      Is a bug in the application. I used fiddler for see what is happening in the call, and the application is sending nothing.
                      I have the ports unlocked, because if not i cant use the https protocol, and my country dont block anything.
                      I think that is something about the language of the computer, that is making a error in the application. You are losing money because that.
                      Regards.
                        Russ @gabi92a
                        @gabi92a, that's a good idea. It could be the Spanish language on the computer. If so I'm sure I can solve that because I should be able to reproduce it by switching my computer to Spanish. Thanks for that idea.
                        EDIT: I tried it - I installed Spanish language on my Windows 10 box and set my region to Spain. Unfortunately it still works for me.
                        Are you using Windows 10?
                        BTW, I appreciate you not giving up. I really want to solve this. Like you said, I'm loosing money.
                          Russ @gabi92a
                          @gabi92a, would you be willing to try this? This will run the agent without the GUI. I suspect the bug is in the GUI.
                          1. Install NodeJS
                          2. Open a cmd prompt
                          3. Run this: node %userprofile%\AppData\Local\TRIGGERcmdAgent\app-1.0.21\resources\app\src\agent.js --console
                          • G
                            gabi92a @Russ
                            @russ Token login failed using the console 😞
                              Russ @gabi92a
                              @gabi92a, thank you for testing. That narrows it down. I created a branch with updated dependencies for you to test (if you're willing). I'm hoping this solves the problem.
                              • Create a folder on your 😄 drive
                              • Open a cmd window, and cd to that folder.
                              • Install git if you don't already have it.
                              • Run this:
                                git clone -b spain https://github.com/rvmey/TRIGGERcmd-Agent.git
                              • cd into the TRIGGERcmd-Agent subfolder.
                              • Run this:
                                npm install
                              • Run this:
                                node src\agent.js --console
                              • Paste in your token
                              If that works, then I believe I can produce a new version that will work on spanish Windows computers.
                              • G
                                gabi92a
                                @russ said in Unable to access to the aplication:
                                Weird error installing: https://gyazo.com/e769546f7621fda85951352a2223a47b
                                Result failed inserting the token: https://gyazo.com/8dfc9f27f419c3a100a7078a7cb843eb
                                Regards.
                                  Russ @gabi92a
                                  Thanks @gabi92a, that's helpful, but I should have added some debugging output.
                                  I added these lines:
                                    console.log("Response from server:");
                                    console.log(response);
                                    console.log("Error from request:");
                                    console.log(error);
                                  Please try this updated code with these steps:
                                  • Open a cmd window, and cd to that c:\TRIGGERcmd\TRIGGERcmd-Agent folder.
                                  • Run this:
                                    git pull
                                  • Run this:
                                  Also, it looks like you ran node install.js instead of npm install. What does that do?
                                  • G
                                    gabi92a @Russ
                                    Result: https://gyazo.com/afe127ffd8783f80a4f1e11b09bb4da5
                                    No, i ran the npm install.
                                    Regards.
                                    • G
                                      gabi92a
                                      Is an error 400, but im not seeing nothing in fiddler, there is no call???? 😞
                                        Russ @gabi92a
                                        @gabi92a, I found out why Fiddler wasn't working. For NodeJS apps like the TRIGGERcmd agent, you have to set these environment variables before you run the node src\agent.js --console command:
                                        set https_proxy=http://127.0.0.1:8888
                                        set http_proxy=http://127.0.0.1:8888
                                        set NODE_TLS_REJECT_UNAUTHORIZED=0
                                        That tells the NodeJS app to use Fiddler as a proxy server.
                                        I found that here: https://weblogs.asp.net/dixin/use-fiddler-with-node-js
                                        Can you try that? Maybe that will give us a clue.
                                        Also, you could try running it after setting this variable to get a bunch of debug output:
                                        set NODE_DEBUG=*
                                        One thing you should know - the agent uses a websocket to connect to the server, and that connection doesn't use the https_proxy variable so Fiddler won't pick that up. The request that's giving us this error doesn't use websockets though, so that shouldn't matter for this troubleshooting.
