<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Unable to access to the aplication]]></title><description><![CDATA[<p dir="auto">Hello, im currenty stucked in the sign in page. I cant enter and its not showing to me any error.</p>
<p dir="auto">GIF: <a href="https://gyazo.com/e119697d037440eb8ae8d605067ebb65" rel="nofollow ugc">https://gyazo.com/e119697d037440eb8ae8d605067ebb65</a></p>
<p dir="auto">My regional configuration is Spanish.</p>
<p dir="auto">Regards and thanks in advance.</p>
]]></description><link>https://www.triggercmd.com/forum/topic/461/unable-to-access-to-the-aplication</link><generator>RSS for Node</generator><lastBuildDate>Fri, 16 Oct 2026 14:02:20 GMT</lastBuildDate><atom:link href="https://www.triggercmd.com/forum/topic/461.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 24 Jul 2019 21:52:13 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Unable to access to the aplication on Tue, 06 Aug 2019 00:30:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/gabi92a" aria-label="Profile: gabi92a">@<bdi>gabi92a</bdi></a>, I found out why Fiddler wasn't working.  For NodeJS apps like the TRIGGERcmd agent, you have to set these environment variables before you run the <strong>node src\agent.js --console</strong> command:</p>
<pre><code>set https_proxy=http://127.0.0.1:8888
set http_proxy=http://127.0.0.1:8888
set NODE_TLS_REJECT_UNAUTHORIZED=0
<p dir="auto">That tells the NodeJS app to use Fiddler as a proxy server.<br />
I found that here:  <a href="https://weblogs.asp.net/dixin/use-fiddler-with-node-js" rel="nofollow ugc">https://weblogs.asp.net/dixin/use-fiddler-with-node-js</a></p>
<p dir="auto">Can you try that?  Maybe that will give us a clue.</p>
<p dir="auto">Also, you could try running it after setting this variable to get a bunch of debug output:</p>
<pre><code>set NODE_DEBUG=*
<p dir="auto">One thing you should know - the agent uses a websocket to connect to the server, and that connection doesn't use the https_proxy variable so Fiddler won't pick that up.  The request that's giving us this error doesn't use websockets though, so that shouldn't matter for this troubleshooting.</p>
]]></description><link>https://www.triggercmd.com/forum/post/1534</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/1534</guid><dc:creator><![CDATA[Russ]]></dc:creator><pubDate>Tue, 06 Aug 2019 00:30:45 GMT</pubDate></item><item><title><![CDATA[Reply to Unable to access to the aplication on Mon, 05 Aug 2019 17:15:44 GMT]]></title><description><![CDATA[<p dir="auto">Is an error 400, but im not seeing nothing in fiddler, there is no call???? <img src="https://www.triggercmd.com/forum/assets/plugins/nodebb-plugin-emoji/emoji/android/1f61e.png?v=6297cc46437" class="not-responsive emoji emoji-android emoji--disappointed" style="height:23px;width:auto;vertical-align:middle" title=":(" alt="😞" /></p>
]]></description><link>https://www.triggercmd.com/forum/post/1533</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/1533</guid><dc:creator><![CDATA[gabi92a]]></dc:creator><pubDate>Mon, 05 Aug 2019 17:15:44 GMT</pubDate></item><item><title><![CDATA[Reply to Unable to access to the aplication on Mon, 05 Aug 2019 17:11:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/russ" aria-label="Profile: russ">@<bdi>russ</bdi></a> said in <a href="/forum/post/1530">Unable to access to the aplication</a>:</p>
<blockquote>
<p dir="auto">node src\agent.js --console</p>
</blockquote>
<p dir="auto">Result: <a href="https://gyazo.com/afe127ffd8783f80a4f1e11b09bb4da5" rel="nofollow ugc">https://gyazo.com/afe127ffd8783f80a4f1e11b09bb4da5</a></p>
<p dir="auto">No, i ran the npm install.</p>
<p dir="auto">Regards.</p>
]]></description><link>https://www.triggercmd.com/forum/post/1532</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/1532</guid><dc:creator><![CDATA[gabi92a]]></dc:creator><pubDate>Mon, 05 Aug 2019 17:11:38 GMT</pubDate></item><item><title><![CDATA[Reply to Unable to access to the aplication on Sun, 04 Aug 2019 20:18:25 GMT]]></title><description><![CDATA[<p dir="auto">Thanks <a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/gabi92a" aria-label="Profile: gabi92a">@<bdi>gabi92a</bdi></a>, that's helpful, but I should have added some debugging output.</p>
<p dir="auto">I added these lines:</p>
<pre><code>  console.log("Response from server:");
  console.log(response);
  console.log("Error from request:");
  console.log(error);
<p dir="auto">Please try this updated code with these steps:</p>
<li>Open a cmd window, and cd to that c:\TRIGGERcmd\TRIGGERcmd-Agent folder.</li>
<li>Run this:<br />
git pull</li>
<li>Run this:<br />
node src\agent.js --console</li>
<li>Paste in your token</li>
<p dir="auto">Also, it looks like you ran <strong>node install.js</strong> instead of <strong>npm install</strong>.  What does that do?</p>
]]></description><link>https://www.triggercmd.com/forum/post/1530</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/1530</guid><dc:creator><![CDATA[Russ]]></dc:creator><pubDate>Sun, 04 Aug 2019 20:18:25 GMT</pubDate></item><item><title><![CDATA[Reply to Unable to access to the aplication on Sun, 04 Aug 2019 16:37:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/russ" aria-label="Profile: russ">@<bdi>russ</bdi></a> said in <a href="/forum/post/1527">Unable to access to the aplication</a>:</p>
<blockquote>
</blockquote>
<p dir="auto">Weird error installing: <a href="https://gyazo.com/e769546f7621fda85951352a2223a47b" rel="nofollow ugc">https://gyazo.com/e769546f7621fda85951352a2223a47b</a></p>
<p dir="auto">Result failed inserting the token: <a href="https://gyazo.com/8dfc9f27f419c3a100a7078a7cb843eb" rel="nofollow ugc">https://gyazo.com/8dfc9f27f419c3a100a7078a7cb843eb</a></p>
]]></description><link>https://www.triggercmd.com/forum/post/1529</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/1529</guid><dc:creator><![CDATA[gabi92a]]></dc:creator><pubDate>Sun, 04 Aug 2019 16:37:36 GMT</pubDate></item><item><title><![CDATA[Reply to Unable to access to the aplication on Sun, 04 Aug 2019 01:04:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/gabi92a" aria-label="Profile: gabi92a">@<bdi>gabi92a</bdi></a>, thank you for testing.  That narrows it down.  I created a branch with updated dependencies for you to test (if you're willing).  I'm hoping this solves the problem.</p>
<li>Create a folder on your <img src="https://www.triggercmd.com/forum/assets/plugins/nodebb-plugin-emoji/emoji/android/1f604.png?v=6297cc46437" class="not-responsive emoji emoji-android emoji--smile" style="height:23px;width:auto;vertical-align:middle" title="C:" alt="😄" /> drive</li>
<li>Open a cmd window, and cd to that folder.</li>
<li>Install <a href="https://git-scm.com/download/win" rel="nofollow ugc">git</a> if you don't already have it.</li>
<li>Run this:<br />
git clone -b spain <a href="https://github.com/rvmey/TRIGGERcmd-Agent.git" rel="nofollow ugc">https://github.com/rvmey/TRIGGERcmd-Agent.git</a></li>
<li>cd into the TRIGGERcmd-Agent subfolder.</li>
<li>Run this:<br />
npm install</li>
<li>Run this:<br />
<p dir="auto">If that works, then I believe I can produce a new version that will work on spanish Windows computers.</p>
]]></description><link>https://www.triggercmd.com/forum/post/1527</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/1527</guid><dc:creator><![CDATA[Russ]]></dc:creator><pubDate>Sun, 04 Aug 2019 01:04:12 GMT</pubDate></item><item><title><![CDATA[Reply to Unable to access to the aplication on Wed, 31 Jul 2019 22:58:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/russ" aria-label="Profile: russ">@<bdi>russ</bdi></a> Token login failed using the console <img src="https://www.triggercmd.com/forum/assets/plugins/nodebb-plugin-emoji/emoji/android/1f61e.png?v=6297cc46437" class="not-responsive emoji emoji-android emoji--disappointed" style="height:23px;width:auto;vertical-align:middle" title=":(" alt="😞" /></p>
]]></description><link>https://www.triggercmd.com/forum/post/1524</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/1524</guid><dc:creator><![CDATA[gabi92a]]></dc:creator><pubDate>Wed, 31 Jul 2019 22:58:48 GMT</pubDate></item><item><title><![CDATA[Reply to Unable to access to the aplication on Wed, 31 Jul 2019 01:25:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/gabi92a" aria-label="Profile: gabi92a">@<bdi>gabi92a</bdi></a>, would you be willing to try this?  This will run the agent without the GUI.  I suspect the bug is in the GUI.</p>
<ol>
<li>Install <a href="https://nodejs.org/en/download/" rel="nofollow ugc">NodeJS</a></li>
<li>Open a <strong>cmd</strong> prompt</li>
<li>Run this:  <strong>node %userprofile%\AppData\Local\TRIGGERcmdAgent\app-1.0.21\resources\app\src\agent.js --console</strong></li>
</ol>
]]></description><link>https://www.triggercmd.com/forum/post/1523</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/1523</guid><dc:creator><![CDATA[Russ]]></dc:creator><pubDate>Wed, 31 Jul 2019 01:25:30 GMT</pubDate></item><item><title><![CDATA[Reply to Unable to access to the aplication on Mon, 29 Jul 2019 23:47:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/gabi92a" aria-label="Profile: gabi92a">@<bdi>gabi92a</bdi></a>, that's a good idea.  It could be the Spanish language on the computer.  If so I'm sure I can solve that because I should be able to reproduce it by switching my computer to Spanish.  Thanks for that idea.</p>
<p dir="auto">EDIT:  I tried it - I installed Spanish language on my Windows 10 box and set my region to Spain.  Unfortunately it still works for me.<br />
Are you using Windows 10?</p>
<p dir="auto">BTW, I appreciate you not giving up.  I really want to solve this.  Like you said, I'm loosing money.</p>
]]></description><link>https://www.triggercmd.com/forum/post/1521</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/1521</guid><dc:creator><![CDATA[Russ]]></dc:creator><pubDate>Mon, 29 Jul 2019 23:47:43 GMT</pubDate></item><item><title><![CDATA[Reply to Unable to access to the aplication on Sun, 28 Jul 2019 17:52:34 GMT]]></title><description><![CDATA[<p dir="auto">Is a bug in the application. I used fiddler for see what is happening in the call, and the application is sending nothing.<br />
I have the ports unlocked, because if not i cant use the https protocol, and my country dont block anything.</p>
<p dir="auto">I think that is something about the language of the computer, that is making a error in the application. You are losing money because that.</p>
]]></description><link>https://www.triggercmd.com/forum/post/1518</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/1518</guid><dc:creator><![CDATA[gabi92a]]></dc:creator><pubDate>Sun, 28 Jul 2019 17:52:34 GMT</pubDate></item><item><title><![CDATA[Reply to Unable to access to the aplication on Fri, 26 Jul 2019 23:26:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/gabi92a" aria-label="Profile: gabi92a">@<bdi>gabi92a</bdi></a>, good luck.  Do you know if Spain has some sort of country wide firewall?  Like China?  I doubt it, but I thought I'd ask.</p>
<p dir="auto">Also, the agent connects to <a href="https://www.triggercmd.com" rel="nofollow ugc">https://www.triggercmd.com</a> over port 443.</p>
]]></description><link>https://www.triggercmd.com/forum/post/1515</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/1515</guid><dc:creator><![CDATA[Russ]]></dc:creator><pubDate>Fri, 26 Jul 2019 23:26:38 GMT</pubDate></item><item><title><![CDATA[Reply to Unable to access to the aplication on Fri, 26 Jul 2019 12:07:35 GMT]]></title><description><![CDATA[<p dir="auto">I will try to using a vpn or something like that, and lets see if i have differences with another range of ip</p>
]]></description><link>https://www.triggercmd.com/forum/post/1514</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/1514</guid><dc:creator><![CDATA[gabi92a]]></dc:creator><pubDate>Fri, 26 Jul 2019 12:07:35 GMT</pubDate></item><item><title><![CDATA[Reply to Unable to access to the aplication on Fri, 26 Jul 2019 12:03:19 GMT]]></title><description><![CDATA[<p dir="auto">Im in Spain, Barcelona. I added the application to the firewall rules, but is making the connection in port 80 right?</p>
]]></description><link>https://www.triggercmd.com/forum/post/1513</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/1513</guid><dc:creator><![CDATA[gabi92a]]></dc:creator><pubDate>Fri, 26 Jul 2019 12:03:19 GMT</pubDate></item><item><title><![CDATA[Reply to Unable to access to the aplication on Thu, 25 Jul 2019 23:26:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/gabi92a" aria-label="Profile: gabi92a">@<bdi>gabi92a</bdi></a>, what country are you in?</p>
<p dir="auto">I wonder if there's some sort of firewall or proxy server between your computer and the TRIGGERcmd servers that's preventing the token login.</p>
<p dir="auto">It's strange though because I looked at the code and it's a pretty straight forward request:</p>
<pre><code>function tokenLogin(token,callback) {
  // Configure the request
  headers.Authorization = 'Bearer ' + token;
  options.headers = headers;
  options.url = urlprefix + '/api/command/list';
  options.method = 'GET';
  // Start the request
  request(options, function (error, response, body) {
    if (!error &amp;&amp; response.statusCode == 200) {
      writeNewTokenToFile(token);
      callback(token);
    } else {
      console.log('Token login failed.');
<p dir="auto">I tried your token and it worked for me - it created a computer in your account.  I deleted it afterward.</p>
<p dir="auto">Also, I removed your token from your post so other people can't create computers in your account, or trigger your commands once you get this working.</p>
]]></description><link>https://www.triggercmd.com/forum/post/1512</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/1512</guid><dc:creator><![CDATA[Russ]]></dc:creator><pubDate>Thu, 25 Jul 2019 23:26:25 GMT</pubDate></item><item><title><![CDATA[Reply to Unable to access to the aplication on Thu, 25 Jul 2019 18:19:22 GMT]]></title><description><![CDATA[<p dir="auto">Is happening the same here: <a href="https://www.triggercmd.com/forum/topic/420/agente-de-windows-en-el-sign-in-no-funciona">https://www.triggercmd.com/forum/topic/420/agente-de-windows-en-el-sign-in-no-funciona</a></p>
]]></description><link>https://www.triggercmd.com/forum/post/1511</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/1511</guid><dc:creator><![CDATA[gabi92a]]></dc:creator><pubDate>Thu, 25 Jul 2019 18:19:22 GMT</pubDate></item><item><title><![CDATA[Reply to Unable to access to the aplication on Thu, 25 Jul 2019 23:26:45 GMT]]></title><description><![CDATA[<p dir="auto">No token exists.  Login to request one.<br />
Attempting to log in with token<br />
(token removed)<br />
Token login failed.</p>
<p dir="auto">Im a software developer, so i know the importance of communicate correctly the bug.</p>
<p dir="auto">I did the step 1 and 2, but i dont think that this is the problem. Try it on a different computer is not a option, and i have a good one.</p>
<p dir="auto">I'm using the token of here: <a href="https://www.triggercmd.com/user/computer/create" rel="nofollow ugc">https://www.triggercmd.com/user/computer/create</a></p>
<p dir="auto">Any ideas?</p>
]]></description><link>https://www.triggercmd.com/forum/post/1510</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/1510</guid><dc:creator><![CDATA[gabi92a]]></dc:creator><pubDate>Thu, 25 Jul 2019 23:26:45 GMT</pubDate></item><item><title><![CDATA[Reply to Unable to access to the aplication on Thu, 25 Jul 2019 01:31:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/gabi92a" aria-label="Profile: gabi92a">@<bdi>gabi92a</bdi></a>, that's a nice way to show me the problem.</p>
<p dir="auto">Can you copy/paste your debug.log file into this thread?  Here's how:</p>
<p dir="auto">Animated GIF:  <a href="https://gyazo.com/61a6e5ac0b20c5e8b0822ae90d62cdf7" rel="nofollow ugc">https://gyazo.com/61a6e5ac0b20c5e8b0822ae90d62cdf7</a></p>
<p dir="auto">Type this into the Open field:  <strong>%userprofile%.triggercmddata\debug.log</strong></p>
<p dir="auto">Also in the meantime, here are some things to try:</p>
<li>Reboot</li>
<li>Turn off Antivirus temporarily</li>
<li>Try it on a different computer</li>
]]></description><link>https://www.triggercmd.com/forum/post/1509</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/1509</guid><dc:creator><![CDATA[Russ]]></dc:creator><pubDate>Thu, 25 Jul 2019 01:31:09 GMT</pubDate></item></channel></rss>
