    2. Tiago Ivanov Lavinas
    Tiago Ivanov LavinasT Offline
    • Posts 7
    • RE: A JavaScript error occurred in the main process
      @Russ I managed to solve hahahahahha. I just rename the folder and it worked! Thank you very much.
      @Russ The antivirus I use is Windows' own.
      @Tiago-Ivanov-Lavinas Also, when I turn on my computer, it asks me to enter the token again, meaning I have to delete my computer on the website and create another one to enter the application.
      @Russ I have another problem. When I try to create my command, it doesn't update on the website or in the "commands.json" file. It only appears on the website when I edit the file itself. The same thing happens when I delete the command in the application but it doesn't delete it in the "commands.json" file or on the website.
      Another problem I'm facing is when I click on "Search for Examples", a window opens saying "Loading examples" and it doesn't load.
      @Russ Yes, I created that file and it worked. Thank you.
    • A JavaScript error occurred in the main process
      This error is appearing for me, when I just added my computer.
    • RE: Install fails everytime, "JavaScript error in the main process.
      @Adam-S It worked. Thanks.
