    Error while installing the triggercmdagent
    8 Posts 2 Posters 432 Views 1 Watching
    • H Offline
      Hannibal
      Hello,
      because of a stupid mistake i had to reinstall my raspberry pi.
      I used these instructions: https://docs.triggercmd.com/#/./InstallRaspberryPi
      But if i try to install with
      sudo apt install ./triggercmdagent_1.0.1_all.deb
      i get the follogwing errors:
      Get:1 /home/hannibal/downloads/triggercmdagent_1.0.1_all.deb triggercmdagent all 1.0.1 [22.2 MB]
      (Reading database ... 91248 files and directories currently installed.)
      Preparing to unpack .../triggercmdagent_1.0.1_all.deb ...
      Unpacking triggercmdagent (1.0.1) ...
      dpkg-deb (subprocess): decompressing archive '/home/hannibal/downloads/triggercmdagent_1.0.1_all.deb' (size=22246140) member 'data.tar': lzma error: compressed data is corrupt
      dpkg-deb: error: <decompress> subprocess returned error exit status 2
      dpkg: error processing archive /home/hannibal/downloads/triggercmdagent_1.0.1_all.deb (--unpack):
       cannot copy extracted data for './usr/share/triggercmdagent/app/src/node.exe' to '/usr/share/triggercmdagent/app/src/node.exe.dpkg-new': unexpected end of file or stream
      Errors were encountered while processing:
      Notice: Download is performed unsandboxed as root as file '/home/hannibal/downloads/triggercmdagent_1.0.1_all.deb' couldn't be accessed by user '_apt'. - pkgAcquire::Run (13: Permission denied)
      Error: Sub-process /usr/bin/dpkg returned an error code (1)
      If i read that right the installation file is corrupted, so i tried several times to download the file, but the error is the same every time.
      So either the file is corrupted or i am doing something wrong, anyone any idea how what to do?
      I hope this is all ok to read, english is not my strong side.
      Greetings Hannibal
        Russ @Hannibal
        @Hannibal, thank you for reporting it! I tested it and ran into the same problem at first, but it's fixed now. Please download it again and try the install again.
        • H Offline
          Hannibal @Russ
          @Russ It seems there is more:
          hannibal@PI-3:~/downloads $ sudo apt install ./triggercmdagent_1.0.1_all.deb
          Note, selecting 'triggercmdagent' instead of './triggercmdagent_1.0.1_all.deb'
          Installing:
            triggercmdagent
          Summary:
            Upgrading: 0, Installing: 1, Removing: 0, Not Upgrading: 0
            Download size: 0 B / 22.2 MB
            Space needed: 0 B / 25.8 GB available
          Selecting previously unselected package triggercmdagent.
          (Reading database ... 73934 files and directories currently installed.)
          Setting up triggercmdagent (1.0.1) ...
          Installing dependenencies from NPM
          npm warn config production Use `--omit=dev` instead.
          npm warn Unknown cli config "--unsafe-perm". This will stop working in the next major version of npm.
          npm warn deprecated source-map-url@0.4.1: See https://github.com/lydell/source-map-url#deprecated
          npm warn deprecated urix@0.1.0: Please see https://github.com/lydell/urix#deprecated
          npm warn deprecated resolve-url@0.2.1: https://github.com/lydell/resolve-url#deprecated
          npm warn deprecated har-validator@5.1.5: this library is no longer supported
          npm warn deprecated source-map-resolve@0.5.3: See https://github.com/lydell/source-map-resolve#deprecated
          npm warn deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
          npm warn deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
          npm warn deprecated posix-argv-parser@2.0.0: No longer maintained
          added 266 packages, and audited 267 packages in 29s
          7 packages are looking for funding
            run `npm fund` for details
          14 vulnerabilities (9 moderate, 3 high, 2 critical)
          To address issues that do not require attention, run:
            npm audit fix
          To address all issues possible (including breaking changes), run:
            npm audit fix --force
          Some issues need review, and may require choosing
          a different dependency.
          Run `npm audit` for details.
          As you can see, the installation was not succesfull.
          And i am again in over my head 🙂
            Russ @Hannibal
            @Hannibal said in Error while installing the triggercmdagent:
            Copy/paste that into ChatGPT to know why, but you can safely ignore that "Notice". Basically it means the _apt user doesn't have access to your user's home directory where the .deb file is, so it's using root to access it instead.
            It looks like the agent is installed now, so you can move on to the next steps:
            triggercmdagent
            ( Paste in your token, and press ENTER. )
            ( Press CTRL-C to quit. )
            The triggercmdagent command should prompt you for a token which you can copy/paste from the Instructions page while logged in at https://www.triggercmd.com
            • H Offline
              Hannibal @Russ
              @Russ Sorry, was away for a few weeks.
              I tried again today, but there is a new problem if i try to use the following:
              node:internal/modules/cjs/loader:1520
                throw err;
              Error: Cannot find module '/usr/lib/triggercmdagent/resources/app/src/agent.js'
                  at Module._resolveFilename (node:internal/modules/cjs/loader:1517:15)
                  at wrapResolveFilename (node:internal/modules/cjs/loader:1071:27)
                  at defaultResolveImplForCJSLoading (node:internal/modules/cjs/loader:1095:10)
                  at resolveForCJSWithHooks (node:internal/modules/cjs/loader:1122:12)
                  at Module._load (node:internal/modules/cjs/loader:1294:5)
                  at wrapModuleLoad (node:internal/modules/cjs/loader:255:19)
                  at Module.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:154:5)
                  at node:internal/main/run_main_module:33:47 {
                code: 'MODULE_NOT_FOUND',
                requireStack: []
              Node.js v24.18.0
              So i looked into the folder, and it does not exist. edit(The whole folder)
              So i thought i did not install the agent and tried to install again with
              triggercmdagent is already the newest version (1.0.1).
              Summary:
                Upgrading: 0, Installing: 0, Removing: 0, Not Upgrading: 0
              So it is installed and it is not installed?
              Any other idea what could be the problem?
              Greetings
              Hannibal
                Russ @Hannibal
                @Hannibal, I see the problem. I told you /usr/lib/triggercmdagent which is the path on Ubuntu, not Raspberry Pi. Sorry about that. I corrected the "next steps" above to match the instructions here.
                It should look like this when you run the triggercmdagent command as root:
                pi@fe5978dee0e5:~$ sudo su -
                root@fe5978dee0e5:~# triggercmdagent
                Daemon install: false
                prompt: token:
                Then run this to install the background agent that will startup as root during boot:
                Then edit /root/.TRIGGERcmdData/commands.json and make sure your commands have ground = background.
                • H Offline
                  Hannibal @Russ
                  @Russ Sorry, i could have looked this up myself, but i was so focused on "there is something wrong with my pi especially" that i did not even try to look into the other thread in the forum.
                  This time i looked around but i could not find a solution, so i am back here again.
                  the Background service is running, i edited the commands.json file, but for some reasen on the website there is no update of the triggers.
                  (I delete all of the pre-installed triggers and put for the moment one of my own in
                   {"trigger":"Zentrale","command":"wakeonlan 74:56:3C:BF:B6:30","ground":background","voice":"zentrale","allowParams": "false","icon":""}
                  but in the Command Management there are still the original triggers in there but not my new one ... even after i rebooted the raspberry pi
                    Russ @Hannibal
                    @Hannibal I see an error in the json. There should be a quote (") at the beginning of the word background.
