    Features request - A few of them :love-you_gesture:
    8 Posts 2 Posters 1.9k Views 1 Watching
    • S Offline
      Smart Communities
      Name PC during install
      Show if a PC is online in PC list
      Show IP address
        Russ @Smart Communities
        @Smart-Communities, these are great ideas. Thank you. I'll work on them.
        EDIT: I got the online/offline status done so far.
        Green = online
        Red = offline
        Black = unknown because the agent hasn't connected or disconnected yet.
        EDIT2: I added the computer's Internet IP address on the computer edit page.
        EDIT3: Now you can name the computer during install. If you leave the field blank, it will default to your computer's hostname.
        S 3 Replies Last reply Reply Quote 0
        • S Offline
          Smart Communities @Russ
          @Russ Damn dude. You're good. This is awesome. Thank you.
          • S Offline
            @Russ the online/offline indicator has already come been very helpful. Thanks again!
            • S Offline
              @Russ Not trying to be "that guy" but I have 2 more.
              Trigger via URL - show a different (hopefully custom) page indicating trigger was submitted. If you close browser instead of just the tab it fires off again when reopening the browser.
              URL shortening or again some way to customize? I can do this manually now by using a redirector to a domain I own but I imagine that's not available to everyone.
              Maybe both these have the same solution.
                @Smart-Communities, do you know about the Bookmark link for each command?
                https://www.triggercmd.com/trigger/bookmark?token=eyJhbGciOiJIUzI1NiIsInR5cCI6IkpXVCJ9.eyJib29rbWFya3VzZXJfaWQiOiIiM2E3N2YyZjgzMTUzMjI0NzM1YjYiLCJjb21wdXRlcl9pZCI6IjYxMDA4MDNiYTdmOGI4MDAxOTY5MzlmOCIsImNvbW1hbmRfaWQiOiI2MzBiYzQ0ZDM3ZTJlNzAwMWEwYjY5NGEiLCJleHBpcmVzSW5TZWNvbmRzIjoiIiwiaWF0IjoxNjcwNDYzMzczfQ.tbTed7KL-lpmD0787t_v8bVAlQ-3rCHv61GKWqes3Fc
                It's a long URL because it includes a jwt.
                At the bottom of it, you can see this red text to verify the trigger was sent:
                You want to be able to customize that screen somehow?
                I understand the desire to shorten it. I figured people would use online url shorteners, but I could consider building one in. That would make the 2D barcode smaller too.
                • S Offline
                  @Russ my bad. I didn't even notice that down there. First time I used triggercmd I didn't see that and kept refreshing.
                  Maybe a redirect if successfully run? To a page that says "Thank you for using TriggerCMD blah blah". If it's just me totally disregard this
                  URL shortener is ok but can't make specific ones. Like if I wanted to reboot HTPC, I can't do http://tinyurl.HTPC_reboot. That's taken.
                  I can however use my redirector and have http://dimitri.com/htpc_reboot.
                  If there's a way to shorted so it's something that can be remembered then that would be cool. Otherwise leave it alone or move confirmation to the top.
                  I'll leave you alone for a while. Thank man.
                    @Smart-Communities, I moved that "Trigger sent. Refresh page to send again." message up to the top. Keep the requests coming. They help. I still plan to update the agent soon with the ability to name the computer during install.
                    BTW, I noticed bookmark URL's weren't running the Alexa routine I had associated with my command. I fixed that too.
