    Alexa Google Panic Alarm
    Raspberry Pi
    google assistan alexa x10 homegenie raspberry pi
    1.4k
    • tuicemenT
      tuicemen
      I got thinking about this last night.
      My security system can be set to automaticaly arm/disarm at a specific time and I can do this via voice. The wireless keyflob have a Panic function as does the security remote. Neither of these I take to bed or even carry with me.
      What better use of Alexa/Google then to trigger a Panic Alarm?
      tuicemenT 2 Replies Last reply Reply Quote 0
      • tuicemenT tuicemen deleted this topic on
      • tuicemenT tuicemen restored this topic on
      • tuicemenT
        tuicemen @tuicemen
        Since creating a trigger script for Arming & Disarming via voice. I believe I'm come up with a way to do this via calling the demo door/window sensor that originally comes with HomeGenie using the API.
        I may rename it to panic and see if I can get TRIGGERcmd to run it.
        • tuicemenT
          tuicemen @tuicemen
          Ok I got this working using the demo Door/Window widget address included in a HomeGenie initial setup.
          here is the line you'd need for the TRIGGERcmd command.json file.
          {"trigger":"Panic","command":"curl http://IP&Port/api/HomeAutomation.HomeGenie/Automation/Programs.Run/401","ground":"background","voice":"Panic","allowParams":"false"},
          Change the IP&Port to the IP & Port of your HG server seems the Security system has to have been in an Armed state for a bit for it to work maybe due the the Arm Away I was using to test things.
          • tuicemenT
            tuicemen @tuicemen
            @tuicemen said in Alexa Google Panic Alarm:
            Wait a min. I have a fitbit that has Alexa ability!😎
            So in theory I always have a remote on me.😖🤣
            • tuicemenT
              tuicemen @tuicemen
              Yesterday I did a clean up of my HomeGenie disabling things I thought I no longer needed. After this I tested my Panic Alarm and discovered there were a few things required that I had left out. These may have been set by default with the initial install of HomeGenie.
              • Besides the Demo-Toggle Door having to be enabled the Virtual Modules Demo program must also be enabled.
              • As well the Automation.Demo 2 "DoorSensor" need to have the options to "Use as security sensor" and "Also trigger when armed Home" checked.
              • The Automation.Demo 2 "DoorSensor" has to be in the closed condition prior to arming the security widget or you will need to send 2 panic calls
