Can't run a batch file
451
  • G
    Gabriel Patrocinio
    I have a minecraft server, and I'm trying to be able to start it remotely, but can't find the right way to use triggercmd to do it.
    Some information:
    I was able to start it through cmd on my pc, with 2 lines of code:
    cd "D:\Users\Patrocinio\Área de Trabalho\tavloa-redonda-mine\Server-tavola-redonda" #that is the path to my file
    run.bat #that executes the file
    But when I used this commands on triggercmd, it didn't seem to work, nothing happened
    R 1 Reply Last reply Nov 9, 2021, 7:30 PM Reply Quote 0
    • R
      Russ @Gabriel Patrocinio
      @Gabriel-Patrocinio , please try adding /d to the cd command.
      Your default drive in cmd is 😄 so you have to switch drives. The /d parameter does that for you.
      • G
        Gabriel Patrocinio
        Just tried it and it didn’t work, nothing happened
        command executed: cd /d “D:/(same path that worked on cmd)”
        R 1 Reply Last reply Nov 10, 2021, 2:28 AM Reply Quote 0
        • R
          @Gabriel-Patrocinio , come to think of it, you don't need to CD to the folder where the batch file is before you run it. You could make your command:
          "d:\Users\Patrocin.....redonda\run.bat"
          • G
            Gabriel Patrocinio
            Didn’t work either, might that be a problem with my computer?
            R 1 Reply Last reply Nov 10, 2021, 12:53 PM Reply Quote 0
            • R
              @Gabriel-Patrocinio , it's not likely a problem with your computer. I might know what it is. Please try moving the run.bat file to a folder like d:\scripts. I think the problem is you have a special non-ascii character in the path.
              • X
                Xander
                The non-ascii could well be the problem.
                But doing a "CD" command and a "run" command is unnecessary so long as you're using the full path.
                Just "D:\Users\Patrocinio**Á**rea de Trabalho\tavloa-redonda-mine\Server-tavola-redonda\run.bat" (with perhaps the special characters fixed) should work.
                • G
                  Gabriel Patrocinio
                  I just found that that it was working this whole time, but it was happening on the background, so thx guys
                  6 out of 8
