    Prevent suppression of cmd window?
    4 Posts 4 Posters 3.3k Views 1 Watching
    • C Offline
      Christian Robinson
      I'm on Windows 10, and I have a process that outputs text information to a cmd window. I want to be able to invoke this with TRIGGERcmd, but when I do the cmd window is suppressed, even though the process is visible in the task manager.
      I've tried various invocations in the commands.json file, including explicitly calling cmd to run the command but the cmd window never appears.
      Normally I would consider the suppression of cmd a good thing, since I have some limited experience with wanting to be able to run programs without a cmd window appearing, and had to come up with some interesting workarounds in some cases. I just need a way to override it.
        Russ @Christian Robinson
        @Christian-Robinson, I found that if you prefix your command with "start" your cmd window will show up in the foreground.
        {"trigger":"Test","command":"start C:\\test\\test.bat","ground":"foreground","voice":"test"},
        I notice it doesn't exit the window when the batch file completed though - I had to add "exit" to the end of the batch file to have it close.
        Contents of test.bat:
        echo hi
        pause
        exit
        C 1 Reply Last reply Reply Quote 1
        • C Offline
          Christian Robinson @Russ
          @Russ Aha! Oddly I thought I had tried that, but I tried it just now and it worked so I'm sure I'm remembering wrong.
          As always, thank you. This is quickly becoming my favorite Alexa skill.
          • XanderX Offline
            Xander
            @Acacia-Hary That'll be harder to do when you're banned for spamming. Bye.
