PS4-Waker troubleshooting
Mac
976
  • B
    BetoFuenzalida
    Hi i'm trying ps4-waker to manage with Alexa. I could start the PS4 with the terminal and the command no problem, but when i create the Trigger it doesnt work. I tried with the line "node %APPDATA%\npm\node_modules\ps4-waker\dist\cli.js", and doesn`t work neither, also route them to where my file is file:///usr/local/lib/node_modules/ps4-waker/dist/cli.js and still won't work. Need help
    R 1 Reply Last reply Mar 8, 2021, 1:12 PM Reply Quote 0
    • R
      Russ @BetoFuenzalida
      @BetoFuenzalida, did you install ps4-waker using a -g like this?
      npm i -g ps4-waker
      That should allow you to run ps4-waker from any directory so you don't have to worry about specifying the full path.
      Also, if you want to add a log file so you can see any errors, you can make your command something like this (this will capture stdout and stderr):
      ps4-waker 1> c:\logs\ps4-waker.log 2>&1
      • R
        Rafa
        Hi @Russ , how are you?
        I'm having the same issue.
        How this log command looks like in macOS?
        R 1 Reply Last reply Mar 12, 2021, 2:48 AM Reply Quote 0
        • R
          Russ @Rafa
          @Rafa, on a mac you can do this:
          On my mac I typed: which ps4-waker
          I saw this output: /usr/local/bin/ps4-waker
          Then I ran this: ls -al /usr/local/bin/ps4-waker
          And I saw something like this: /usr/local/bin/ps4-waker -> ../lib/node_modules/ps4-waker/dist/cli.js
          So I knew the path for ps4-waker's cli.js file is /usr/local/lib/node_modules/ps4-waker/dist/cli.js
          I typed this to find my Node JS executable: which node
          It showed me this path: /Users/russ/.nvm/versions/node/v8.17.0/bin/node
          I made ps4-waker my command in the TRIGGERcmd GUI editor this:
          /Users/russ/.nvm/versions/node/v8.17.0/bin/node /usr/local/lib/node_modules/ps4-waker/dist/cli.js > ~/Desktop/ps4-waker.log 2>&1
          This part is meant to log the output of the ps4-waker command: > ~/Desktop/ps4-waker.log 2>&1
          When I looked at the log I saw this:
          Could not detect any matching PS4 device
          Your paths will likely be different depending on the output of your which commands.
          Another way to find the path to your cli.js file is this command: find / | grep ps4-waker/dist/cli.js
          • B
            Bráulio Betônico
            if I type in the terminal, the system runs normally, I still linked the triggnercmd on Alexa Amazon, it recognizes the APP, she (Alexa) says she recognized a new APP, but it doesn't trigger the PS4. But, when I go to the terminal and type ps4-waker turns on, and ps4 waker standby it goes to sleep, but by the triggercmd command, it doesn't work, I've uninstalled it several times, I redid all the configuration and nothing. Anyone to help?alt textalt textalt textalt textalt textalt textalt text
            R 1 Reply Last reply Jul 30, 2021, 2:26 AM Reply Quote 0
            • R
              Russ @Bráulio Betônico
              @Bráulio-Betônico, please show me the output of this command:
              which node
              If it shows something like /Users/russ/.nvm/versions/node/v8.17.0/bin/node, then your full command should be:
              • B
                Bráulio Betônico
                alt text @Russ
                • B
                  Bráulio Betônico
                  @Russ It worked out! I love you!
                  • B
                    Bráulio Betônico
                    @Russ Thank you very, very much! I am really happy! Would you have a command to put it to sleep?
                    R 1 Reply Last reply Jul 31, 2021, 12:42 AM Reply Quote 0
                    • R
                      @Bráulio-Betônico, awesome. I'm glad that worked.
                      I looked up the documentation here and I see this is the command to put the PS4 on standby:
                      ps4-waker standby
                      So in your case:
                      /usr/local/bin/node /usr/local/lib/node_modules/ps4-waker/dist/cli.js standby
                      • B
                        Bráulio Betônico
                        @Russ said in PS4-Waker troubleshooting:
                        Thank you very much. worked correctly.
                        • T tuicemen referenced this topic on Jan 20, 2022, 2:32 PM
