Config file keeps getting reset
    A Former User
    Hey all,
    I added some new triggers, but they keep getting removed. I've checked their format and they seem okay, but i might be missing something.
      {"trigger":"Shutdown PC","command":"ssh user@pc.local "shutdown -s -t 60"","ground":"background","voice":"Shutdown my PC","allowParams": "false"},
      {"trigger":"Restart PC","command":"ssh user@pc.local "shutdown -r -t 60"","ground":"background","voice":"Restart my PC","allowParams": "false"},
      {"trigger":"Hibernate PC","command":"ssh user@pc.local "shutdown -h -t 60"","ground":"background","voice":"Hibernate my PC","allowParams": "false"},
      {"trigger":"Sleep PC","command":"ssh user@pc.local "nircmd standby"","ground":"background","voice":"Sleep my PC","allowParams": "false"},
      {"trigger":"Abort PC","command":"ssh user@pc.local "shutdown -a"","ground":"background","voice":"Abort","allowParams": "false"}
    Console output of installdaemon.sh
    pi@pihole:~ $ sudo /usr/share/triggercmdagent/app/src/installdaemon.sh
    Daemon install: true
    Logging in with saved token.
    Checking if the 5e861xxxxxxxxxxxxx193d3fe6 computer exists.
    This computer was deleted from your account.  Login to recreate it.
       Active: active (running) since Sat 2020-04-04 12:23:29 BST; 3 days ago
     Main PID: 275 (node)
       Memory: 33.7M
               └─275 node /usr/share/triggercmdagent/app/src/daemon.js --run /root/.TRIGGERcmdData
    Apr 07 19:04:38 pihole env[275]: Write backup completed.
    Apr 07 19:04:39 pihole env[275]: Initiated command removals
    Apr 07 19:04:39 pihole env[275]: Initiated command adds
    Apr 07 19:04:39 pihole env[275]: Failed while trying add a trigger.
    Apr 07 19:05:28 pihole env[275]: Failed while trying add a trigger.
    Thanks!
    R 1 Reply Last reply Apr 7, 2020, 9:19 PM Reply Quote 0
    • R
      Russ @A Former User
      @Lewis-S, I see two quotes in a row at the end of your commands. There should be only one.
      When the agent sees invalid json it reverts the file to the previous version.
        A Former User
        That makes sense.
        My commands need the quotes. Is there anyway of not needing to make scripts for each trigger?
        I read online somewhere about escape characters, but I'm not sure where I'd need them.
        R 1 Reply Last reply Apr 8, 2020, 3:09 PM Reply Quote 0
        • R
          Russ @A Former User
          @Lewis-S, to use quotes within quotes you generally have to "escape" them with backslashes. Like this:
          "She said \"hi\" to me"
          ? 1 Reply Last reply Apr 8, 2020, 3:34 PM Reply Quote 0
            A Former User @Russ
            @Russ I see.
            It works, but the command is not working when it gets executed, as the ""s are being interpreted.
            I guess I'll have to use script files after all.
            Thank you very much!
            Edit: (split)
            2 out of 5
