trigger cmd on arch linux
is there a way to get trigger cmd running on arch linux? i see there is a linux agent however .deb is debian based distros and rpm i beleive is what ever fedora is based on. i use manjaro which is arch linux with a noob friendly installion (lol) and uses pacman to install which does not allow for the installion of .rpm or .deb files
any help would be appreciated. -
Hey @Terry-King, I'll look into it.
@Terry-King, I'm not planning to make an archlinux package, but you could install the agent from the Github repo like this:
pacman -Sy pacman -S nodejs npm git git clone https://github.com/rvmey/TRIGGERcmd-Agent.git cd TRIGGERcmd-Agent npm install node ./src/agent.js --console -
@Russ will it work as well as on windows?
@Russ here is a recording of my terminal output when i run those commands https://asciinema.org/a/xxStYX1LqovlHqvpDsf3vuY6G
@Terry-King, you were close. You can generally ignore those warnings when you run npm install. So you probably just had to run this when you were in the TRIGGERcmd-Agent folder:
node ./src/agent.js --consoleYou're not running X Windows right? That command runs the agent in forground mode and doesn't give you the tray icon or the GUI command editor, so you'll have to edit your ~/.TRIGGERcmdData/commands.json file with a text editor.
@Terry-King, I think it will work if you try again, and just run this command:
ok i got the app installed (it asked me for my token) but there isnt a GUI? how do i set up commands?
@Terry-King, no GUI when you run it that way.
You have to edit the ~/.TRIGGERcmdData/commands.json file to add commands.
@Russ is there a video that shows how to do this?
@Terry-King, no, but that's a good idea. I'll work on that - hopefully tomorrow.
EDIT: It's done: https://youtu.be/Iv6ifjHyWF4
Thank Russ for this , but on arch how I run the triggercmd on boot?
my goal is wakeonlan....thankyuo
@Tiago-Mártires, I answered here: https://www.triggercmd.com/forum/topic/625/boot-on-arch
@Russ said in trigger cmd on arch linux:
Sorry to open again this topic, but when i call 'npm install' this error showed and close the build:
npm ERR! notsup Unsupported platform for node-windows@0.1.14: wanted {"os":"win32","arch":"any"} (current: {"os":"linux","arch":"x64"}) npm ERR! notsup Valid OS: win32 npm ERR! notsup Valid Arch: any npm ERR! notsup Actual OS: linux npm ERR! notsup Actual Arch: x64I think strange, because, the win32 appear... but i use manjaro..
@mayron, thanks for reporting this.
The package.json that's in-place now might be the windows version. Please try copying the ubuntupackage.json or redhatpackage.json file over-top of package.json like this:
cp ubuntupackage.json package.jsonThen try npm install again.
I don't have time right this minute to test it. I'll add a archbuild.sh file to that repo once I know which package.json works.
@Russ thanks for the answer, now it made the correct build, but i remember that in ubuntu request for the token when I call the command .. here's the message below
$ node ./src/agent.js --console Run installdaemon.sh to install the triggercmdagent daemon so it runs during boot Daemon install: false No token exists. Login to request one. prompt: token: (node:369045) Warning: Accessing non-existent property 'padLevels' of module exports inside circular dependency -
@mayron and I talked over chat and it's working for him now. I tested it too. We just had to press enter at that Warning prompt, then paste in the token. I'll try to get rid of that warning, but at least it works as-is.
I think one of the packages was updated to the latest version which introduced that warning message.
@Russ thanks!
