    command pm2 start or stop mm
    Instructions
    2.4k
    • C
      ccd
      Re: Raspberry Pi setup
      hello,
      very nice to use this application...but i can't use my command pm2 start mm and pm2 stop mm...i have a raspebrry pi3 with magicmirror..in a terminal with pi@raspberrypi i can work with pm2 start or stop mm to display magicmirror...How can i writte with the command trigger?
      {"trigger":"start mm","command":"pm2 start mm","ground":"background","voice":"magic on","allowParams": "false"},
      {"trigger":"stop mm","command":"pm2 stop mm":"background","voice":"magic off","allowParams": "false"},
      a sudo reboot in the command is ok
      thanks for help
        Russ @ccd
        @ccd, your triggercmdagent daemon is running as root, but I think you want that pm2 command to run as pi, so please try changing your command to this:
        su - pi -c 'pm2 start mm'
        That su command will run as root, then it will run the pm2 command as the pi user.
        • C
          ccd
          Hello russ,
          I will try this. Thanks for response 🙂
          • C
            ccd @Russ
            my command pm2 start (or stop) is working in "pi@raspberrypi $ pm2 start mm"
            the command with : "su - pi -c 'pm2 start mm'" doesn 't work..sorry i am a beginner
            thanks
            • C
              ccd
              it's ok with sudo before...thanks again 🙂 🙂 🙂 🙂 🙂 🙂 🙂 🙂
                Russ @ccd
                @ccd, awesome, I'm glad you got it working. Sounds like this is the command that worked:
