It all worked out! Thank you very much Russ, you helped me a lot.@russ
RE: i can't add trigger on my raspberry pi
@russ said in i can't add trigger on my raspberry pi:
hello, I received the following output● triggercmdagent.service - TRIGGERcmd Agent Loaded: loaded (/etc/systemd/system/triggercmdagent.service; enabled; vend> Active: active (running) since Fri 2022-05-06 00:28:26 BST; 1 day 12h ago Main PID: 404 (node) Tasks: 11 (limit: 1598) CPU: 3.577s CGroup: /system.slice/triggercmdagent.service └─404 node /usr/share/triggercmdagent/app/src/daemon.js --run /roo> May 07 13:09:12 raspberrypi env[404]: _-|>_- (attempt #3) May 07 13:09:12 raspberrypi env[404]: May 07 13:09:12 raspberrypi env[404]: |> Socket reconnected successfully a> May 07 13:09:12 raspberrypi env[404]: \___/ being offline at least 132038.91 > May 07 13:09:12 raspberrypi env[404]: |> Now connected to https://www.trig> May 07 13:09:12 raspberrypi env[404]: \___/ For help, see: http://bit.ly/2q0Q> May 07 13:09:12 raspberrypi env[404]: (using sails.io.js node SDK @v1.1> May 07 13:09:12 raspberrypi env[404]: Connected at: Sat May 07 2022 13> May 07 13:09:12 raspberrypi env[404]: { message: 'Subscribed to null!' } May 07 13:09:12 raspberrypi env[404]: { message: 'Subscribed to null!' } ~ ~ ~ lines 1-19/19 (END)...skipping... ● triggercmdagent.service - TRIGGERcmd Agent Loaded: loaded (/etc/systemd/system/triggercmdagent.service; enabled; vendor preset: enabled) Active: active (running) since Fri 2022-05-06 00:28:26 BST; 1 day 12h ago Main PID: 404 (node) Tasks: 11 (limit: 1598) CPU: 3.577s CGroup: /system.slice/triggercmdagent.service └─404 node /usr/share/triggercmdagent/app/src/daemon.js --run /root/.TRIGGERcmdData May 07 13:09:12 raspberrypi env[404]: _-|>_- (attempt #3) May 07 13:09:12 raspberrypi env[404]: May 07 13:09:12 raspberrypi env[404]: |> Socket reconnected successfully after May 07 13:09:12 raspberrypi env[404]: \___/ being offline at least 132038.91 seconds. May 07 13:09:12 raspberrypi env[404]: |> Now connected to https://www.triggercmd.com. May 07 13:09:12 raspberrypi env[404]: \___/ For help, see: http://bit.ly/2q0QDpf May 07 13:09:12 raspberrypi env[404]: (using sails.io.js node SDK @v1.1.13) May 07 13:09:12 raspberrypi env[404]: Connected at: Sat May 07 2022 13:09:12 GMT+0100 (British Summer Time) May 07 13:09:12 raspberrypi env[404]: { message: 'Subscribed to null!' } May 07 13:09:12 raspberrypi env[404]: { message: 'Subscribed to null!' } -
@russ hello russ, I edited the commands.json to:
{"trigger":"python test","command":"python /root/led.py","ground":"background","voice":""}
but when saving I can't see the trigger on the site, only Gnome Editor. Could you help me? -
Hello Russ, I managed to install the Trigger cmd on my Raspberry pi, insclusive managed to see it on the site. But I'm having trouble adding a Trigger. I could not edit the file: commands.json. I opened the terminal as root user, and typed the following code: /root/. TRIGGERcmdData/commands.json, and I received the output: Permission denied. I'd like you to help me. Thank you right now.
