[SOLVED] Get Alexa responses that contain a variable value taken from a script.
  • Hi everyone,
    Greetings from Brazil.
    Can I receive responses from Alexa that contain a variable value taken from a Python script, for example?
    A simple example:
    I ask Alexa what time my workday should end. Through a routine.
    A Python script runs and returns the end time to Alexa, and she responds:
    "Your workday ends at $endtime"
    Example:
    "Your workday ends at 17:06"
    It's possible?
    Thanks in advance.
    Best regards,
  • After searching the forum, I found some tips that led me here.
    I have created a simple python script.
    from the Popen import thread
    result = 'Nineteen'
    Popen("C:\\Users\\PS\\.TRIGGERcmdData \\SendResult.bat "+str(result))
    The file "results.log" is written with a new line:
    {"data": [{"name": "Result", "voice": "Result", "voiceReply": "Executing {{trigger}} on {{computer}} with {{result}}", "allowParams ": false," user ":" MY_USER "," computer ":" MY_COMPUTER "," switch_is_on ": false," runCount ": 3," createdAt ":" 2020-10-16T04: 13: 20.240Z "," updatedAt ":" 2020-10-16T04: 30: 55.695Z "," lastResult ":" Nineteen "," id ":" MY_ID "}]," message ":" Result of command updated successfully. "}
    But Alexa doesn't answer anything. Could you help me?```
  • @psandimp, you can use these fields in the Voice Reply field:
    • {{trigger}}
    • {{computer}}
    • {{params}}
    • {{result}}
    Please try this python script:
    import os
    result = 'Nineteen'
    sts = os.system(os.environ['USERPROFILE'] + "\\.TRIGGERcmdData\\SendResult.bat "+str(result))
    I said, "Alexa, ask triggercmd to run result."
    Alexa replied, "Result is nineteen."
    I tested with these command settings:
    This only works with the non-Smart Home Alexa skill / Google action.
  • Dear @Russ,
    The problem has been solved.
    I was trying to run this command through the TriggerCMD Smart Home Skill.
    I just switched to the non-Smart Home Alexa skill and it worked great.
    Thank you so much!
    Best regards,
  • Awesome @psandimp. Yea I think probably a lot of people start using one skill and they don't realize the other one exists.
