<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Help with Alexa - TriggerCMD]]></title><description><![CDATA[<p dir="auto">Hey,</p>
<p dir="auto">It's my first time here, and i had some problems with my alexa and triggercmd skill's.</p>
<p dir="auto">When I configure a command in triggercmd, my alexa recognizes it, but if I say "open any program" it doesn't work. I need to tell alexa to "close any program" and then she will open the program that I need. <strong>I don't know why the commands are reversed.</strong></p>
<p dir="auto"><strong>Would it be a problem in alexa or triggercmd? I'm using TRIGGERcmd Smart Home.</strong></p>
<p dir="auto">Tks</p>
]]></description><link>https://www.triggercmd.com/forum/topic/935/help-with-alexa-triggercmd</link><generator>RSS for Node</generator><lastBuildDate>Sat, 17 Oct 2026 09:24:38 GMT</lastBuildDate><atom:link href="https://www.triggercmd.com/forum/topic/935.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 06 Oct 2020 22:10:16 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Help with Alexa - TriggerCMD on Sun, 11 Oct 2020 02:31:59 GMT]]></title><description><![CDATA[<p dir="auto">Thanks <a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/gfmendes" aria-label="Profile: gfmendes">@<bdi>gfmendes</bdi></a>.  I don't know why certain words would work better.  The TRIGGERcmd Smart Home Alexa skill simulates a light switch for each command, so I thought ligar and desligar would work best.  Google Translate tells me those are the translations for "turn on" and "turn off" which is how I tend say it in English.  I can also say, "calculator off".</p>
<p dir="auto">This page gives some background too if you're interested:<br />
<a href="https://www.amazon.com.br/gp/help/customer/display.html/ref=hp_bc_nav?ie=UTF8&amp;nodeId=201749260" rel="nofollow ugc">https://www.amazon.com.br/gp/help/customer/display.html/ref=hp_bc_nav?ie=UTF8&amp;nodeId=201749260</a></p>
]]></description><link>https://www.triggercmd.com/forum/post/2979</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/2979</guid><dc:creator><![CDATA[Russ]]></dc:creator><pubDate>Sun, 11 Oct 2020 02:31:59 GMT</pubDate></item><item><title><![CDATA[Reply to Help with Alexa - TriggerCMD on Sun, 11 Oct 2020 01:37:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/russ" aria-label="Profile: Russ">@<bdi>Russ</bdi></a> Try this</p>
<p dir="auto">Manage Your Content and Devices &gt; Preferences &gt; Country/Region Settings</p>
<p dir="auto">You will need to put any andress here in Brazil to change. Your kindle account comes too if u want.</p>
<p dir="auto">If u need help with Portugues or test, let me know.</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/russ" aria-label="Profile: Russ">@<bdi>Russ</bdi></a>, another question. Why to open some triggers, I need to use differents activation words?  Like 'ativar', 'abrir', 'ligar'<br />
Some triggers i can use 'ativar',  others 'abrir' because they don't understand 'ativar'.</p>
]]></description><link>https://www.triggercmd.com/forum/post/2978</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/2978</guid><dc:creator><![CDATA[gfmendes]]></dc:creator><pubDate>Sun, 11 Oct 2020 01:37:53 GMT</pubDate></item><item><title><![CDATA[Reply to Help with Alexa - TriggerCMD on Sat, 10 Oct 2020 14:50:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/gfmendes" aria-label="Profile: gfmendes">@<bdi>gfmendes</bdi></a>, thank you.  How did you change your Amazon account to USA?  I'd like to switch mine to Brazil to see if I can reproduce and fix the problem.</p>
]]></description><link>https://www.triggercmd.com/forum/post/2977</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/2977</guid><dc:creator><![CDATA[Russ]]></dc:creator><pubDate>Sat, 10 Oct 2020 14:50:10 GMT</pubDate></item><item><title><![CDATA[Reply to Help with Alexa - TriggerCMD on Fri, 09 Oct 2020 21:52:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/russ" aria-label="Profile: Russ">@<bdi>Russ</bdi></a> , my Alexa was with the last version and i tried all this things.</p>
<p dir="auto">Looking how to unlock new skills to Alexa, i changed my Amazon Account to USA, and now  <strong>"ligar/desligar" are fuction very well!</strong></p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/russ" aria-label="Profile: Russ">@<bdi>Russ</bdi></a> thank u  so much for all your help.</p>
]]></description><link>https://www.triggercmd.com/forum/post/2972</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/2972</guid><dc:creator><![CDATA[gfmendes]]></dc:creator><pubDate>Fri, 09 Oct 2020 21:52:54 GMT</pubDate></item><item><title><![CDATA[Reply to Help with Alexa - TriggerCMD on Fri, 09 Oct 2020 11:50:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/gfmendes" aria-label="Profile: gfmendes">@<bdi>gfmendes</bdi></a>, please try changing your command's voice word, and verify it updates the Alexa device you showed in the screenshot.</p>
<p dir="auto">Yes that is the right skill for running commands as if they were switches you can have Alexa turn on and off.</p>
]]></description><link>https://www.triggercmd.com/forum/post/2969</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/2969</guid><dc:creator><![CDATA[Russ]]></dc:creator><pubDate>Fri, 09 Oct 2020 11:50:59 GMT</pubDate></item><item><title><![CDATA[Reply to Help with Alexa - TriggerCMD on Fri, 09 Oct 2020 02:29:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/russ" aria-label="Profile: Russ">@<bdi>Russ</bdi></a></p>
<p dir="auto">No problem.  Am'i using the right skill?<br />
If i "play" any trigger on site, they run it, but no way using voice.</p>
<p dir="auto">Take a look. They are like this.<br />
<img src="/forum/assets/uploads/files/1602210269228-16250b5f-a6ff-48b9-9839-7a04a398fefe-image.png" alt="16250b5f-a6ff-48b9-9839-7a04a398fefe-image.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://www.triggercmd.com/forum/post/2962</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/2962</guid><dc:creator><![CDATA[gfmendes]]></dc:creator><pubDate>Fri, 09 Oct 2020 02:29:32 GMT</pubDate></item><item><title><![CDATA[Reply to Help with Alexa - TriggerCMD on Fri, 09 Oct 2020 02:08:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/gfmendes" aria-label="Profile: gfmendes">@<bdi>gfmendes</bdi></a>, sorry, I had the URL's backward at first.  I fixed them.  That's URL is for the Smart Home skill that allows you to say, "ligar/desligue calculator" because your commands become Alexa smart home devices.</p>
<p dir="auto">Please tell me if you see your commands as devices here:<br />
<a href="https://alexa.amazon.com/spa/index.html#appliances" rel="nofollow ugc">https://alexa.amazon.com/spa/index.html#appliances</a></p>
<p dir="auto">They should look like this:<br />
<img src="/forum/assets/uploads/files/1602209273881-ac56aed0-e816-4abe-a693-e7a8e3ce4a69-image.png" alt="ac56aed0-e816-4abe-a693-e7a8e3ce4a69-image.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://www.triggercmd.com/forum/post/2961</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/2961</guid><dc:creator><![CDATA[Russ]]></dc:creator><pubDate>Fri, 09 Oct 2020 02:08:53 GMT</pubDate></item><item><title><![CDATA[Reply to Help with Alexa - TriggerCMD on Fri, 09 Oct 2020 00:43:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/russ" aria-label="Profile: Russ">@<bdi>Russ</bdi></a></p>
<p dir="auto">I'm using this skill</p>
<p dir="auto">Original skill: <a href="https://www.amazon.com.br/VanderMey-Consulting-LLC-TRIGGERcmd-Smart/dp/B07P1MMFRP" rel="nofollow ugc">https://www.amazon.com.br/VanderMey-Consulting-LLC-TRIGGERcmd-Smart/dp/B07P1MMFRP</a><br />
Alexa, pergunte Execute Comando executar calculator</p>
<p dir="auto">Could u confirm that I'm right please?</p>
]]></description><link>https://www.triggercmd.com/forum/post/2960</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/2960</guid><dc:creator><![CDATA[gfmendes]]></dc:creator><pubDate>Fri, 09 Oct 2020 00:43:47 GMT</pubDate></item><item><title><![CDATA[Reply to Help with Alexa - TriggerCMD on Fri, 09 Oct 2020 02:05:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/gfmendes" aria-label="Profile: gfmendes">@<bdi>gfmendes</bdi></a>, please confirm you're using the Smart Home skill.</p>
<p dir="auto">Original skill:  <a href="https://www.amazon.com.br/gp/product/B074TV61DK" rel="nofollow ugc">https://www.amazon.com.br/gp/product/B074TV61DK</a><br />
<p dir="auto">Smart Home skill:  <a href="https://www.amazon.com.br/VanderMey-Consulting-LLC-TRIGGERcmd-Smart/dp/B07P1MMFRP" rel="nofollow ugc">https://www.amazon.com.br/VanderMey-Consulting-LLC-TRIGGERcmd-Smart/dp/B07P1MMFRP</a><br />
Alexa, ligar/desligue calculator</p>
<p dir="auto">EDIT:  I had the url's backward at first.  I corrected them above.</p>
]]></description><link>https://www.triggercmd.com/forum/post/2959</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/2959</guid><dc:creator><![CDATA[Russ]]></dc:creator><pubDate>Fri, 09 Oct 2020 02:05:14 GMT</pubDate></item><item><title><![CDATA[Reply to Help with Alexa - TriggerCMD on Thu, 08 Oct 2020 17:35:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/russ" aria-label="Profile: Russ">@<bdi>Russ</bdi></a>, yes, I've seen this video, I even used it to configure my Alexa and TriggerCMD.</p>
<p dir="auto">I'm using the Off Command field like you said, but not worked yet with Portuguese commands with "ligue" and "desligue" not even with the Calculator or Notepad.</p>
<p dir="auto">Do u have another ideia about it?</p>
]]></description><link>https://www.triggercmd.com/forum/post/2958</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/2958</guid><dc:creator><![CDATA[gfmendes]]></dc:creator><pubDate>Thu, 08 Oct 2020 17:35:01 GMT</pubDate></item><item><title><![CDATA[Reply to Help with Alexa - TriggerCMD on Wed, 07 Oct 2020 22:12:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/gfmendes" aria-label="Profile: gfmendes">@<bdi>gfmendes</bdi></a>, yes, it works in Brazil in Portuguese.</p>
<p dir="auto">Have you seen <a href="https://www.youtube.com/watch?v=FTxIabp8CRg" rel="nofollow ugc">this video</a>?</p>
<p dir="auto">You should be able to say these things:</p>
<li>ligue a calculadora</li>
<li>desligue a calculadora</li>
<p dir="auto">Both ligue and desligue should run the command, unless you use the Off Command field, in which case desligue should run that one.</p>
]]></description><link>https://www.triggercmd.com/forum/post/2955</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/2955</guid><dc:creator><![CDATA[Russ]]></dc:creator><pubDate>Wed, 07 Oct 2020 22:12:45 GMT</pubDate></item><item><title><![CDATA[Reply to Help with Alexa - TriggerCMD on Wed, 07 Oct 2020 19:31:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/russ" aria-label="Profile: Russ">@<bdi>Russ</bdi></a>,</p>
<p dir="auto">I think that i discovered the problem. I switched my Alexa to English and the commands worked. But I live in Brazil, does the APP not work here in Portuguese?</p>
]]></description><link>https://www.triggercmd.com/forum/post/2953</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/2953</guid><dc:creator><![CDATA[gfmendes]]></dc:creator><pubDate>Wed, 07 Oct 2020 19:31:53 GMT</pubDate></item><item><title><![CDATA[Reply to Help with Alexa - TriggerCMD on Wed, 07 Oct 2020 11:41:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/russ" aria-label="Profile: Russ">@<bdi>Russ</bdi></a> said in <a href="/forum/post/2938">Help with Alexa - TriggerCMD</a>:</p>
<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/gfmendes" aria-label="Profile: gfmendes">@<bdi>gfmendes</bdi></a>, with the TRIGGERcmd Smart Home skill, if you setup your command like this, with Allow Parameters = true and an Off Command set, then you can say, "turn on calculator" to run <strong>calc</strong> and "turn off calculator" to run <strong>taskkill /f /im calculator.exe</strong> to close it.</p>
<p dir="auto"><img src="/forum/assets/uploads/files/1602025145142-1ba45b40-fe0b-49b1-888c-9f75f5ea01f9-image.png" alt="1ba45b40-fe0b-49b1-888c-9f75f5ea01f9-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">If you have Allow Parameters = false, it will run <strong>calc</strong> whether you say turn on or turn off calculator because it blocks the <strong>on</strong> or <strong>off</strong> parameter coming from the skill.</p>
</blockquote>
<p dir="auto">Hey <a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/russ" aria-label="Profile: Russ">@<bdi>Russ</bdi></a> , tks for this fast answer.</p>
<p dir="auto">I did exactly what you said  to me, and I still have the same problem. On my cellphone notification pops up "to turn on this trigger say it '<strong>turn OFF</strong> and the name of the trigger', but Alexa's voice say "to turn on this trigger say it '<strong>turn ON</strong> and the name of the trigger'.</p>
<p dir="auto"><strong>I don't know why the commands are reversed yet. Alexa's voice says one thing (to activate the command, use "turn on") and alexa's notification says another (to activate the command, use "turn off"), and the trigger only activates if I use "turn off".</strong></p>
]]></description><link>https://www.triggercmd.com/forum/post/2951</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/2951</guid><dc:creator><![CDATA[gfmendes]]></dc:creator><pubDate>Wed, 07 Oct 2020 11:41:47 GMT</pubDate></item><item><title><![CDATA[Reply to Help with Alexa - TriggerCMD on Tue, 06 Oct 2020 23:03:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/gfmendes" aria-label="Profile: gfmendes">@<bdi>gfmendes</bdi></a>, with the TRIGGERcmd Smart Home skill, if you setup your command like this, with Allow Parameters = true and an Off Command set, then you can say, "turn on calculator" to run <strong>calc</strong> and "turn off calculator" to run <strong>taskkill /f /im calculator.exe</strong> to close it.</p>
]]></description><link>https://www.triggercmd.com/forum/post/2938</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/2938</guid><dc:creator><![CDATA[Russ]]></dc:creator><pubDate>Tue, 06 Oct 2020 23:03:02 GMT</pubDate></item></channel></rss>
