<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[How to connect the PC after sleep mode]]></title><description><![CDATA[<p dir="auto">Which command can I put for my PC to return from sleep</p>
<p dir="auto">started sleep mode:<br />
Command:pmset sleepnow</p>
<p dir="auto">which command can i return?</p>
<hr />
<p dir="auto">Qual comando posso colocar no meu PC para retornar do modo de suspensão?</p>
<p dir="auto">iniciou o modo de suspensão:<br />
Comando: pmset sleepnow</p>
<p dir="auto">qual comando posso retornar?</p>
]]></description><link>https://www.triggercmd.com/forum/topic/791/how-to-connect-the-pc-after-sleep-mode</link><generator>RSS for Node</generator><lastBuildDate>Mon, 20 Apr 2026 16:24:42 GMT</lastBuildDate><atom:link href="https://www.triggercmd.com/forum/topic/791.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 20 Jul 2020 08:10:29 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to How to connect the PC after sleep mode on Mon, 21 Sep 2020 22:14:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://www.triggercmd.com/forum/uid/4707">@Rafael-Sathler</a>, I just realized these are Mac commands and the topic was in the Windows section, so I moved this over to the Mac section.</p>
<p dir="auto">I wonder if that's where the confusion came from.</p>
]]></description><link>https://www.triggercmd.com/forum/post/2871</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/2871</guid><dc:creator><![CDATA[Russ]]></dc:creator><pubDate>Mon, 21 Sep 2020 22:14:30 GMT</pubDate></item><item><title><![CDATA[Reply to How to connect the PC after sleep mode on Mon, 21 Sep 2020 16:45:47 GMT]]></title><description><![CDATA[<p dir="auto">Tentei criar a programação usando este comando que vc informou, mas não consegui nem mesmo suspender. Onde encontrou este comando?</p>
]]></description><link>https://www.triggercmd.com/forum/post/2870</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/2870</guid><dc:creator><![CDATA[Rafael Sathler]]></dc:creator><pubDate>Mon, 21 Sep 2020 16:45:47 GMT</pubDate></item><item><title><![CDATA[Reply to How to connect the PC after sleep mode on Mon, 17 Aug 2020 23:19:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://www.triggercmd.com/forum/uid/3920">@Robertofilho</a>, you can't run commands on your computer when it's in sleep mode, so you would have to use another computer on your network to send it a wake-on-lan magic packet to take it out of sleep mode first.</p>
<p dir="auto">What you could do is use these commands to turn the display off and on:</p>
<pre><code>Display off:  pmset displaysleepnow
Display on:   caffeinate -u -t 1</code></pre>
]]></description><link>https://www.triggercmd.com/forum/post/2535</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/2535</guid><dc:creator><![CDATA[Russ]]></dc:creator><pubDate>Mon, 17 Aug 2020 23:19:31 GMT</pubDate></item></channel></rss>
