<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[How to turn my WINDOWS pc on using wol?]]></title><description><![CDATA[<p dir="auto">Can someone help me?</p>
]]></description><link>https://www.triggercmd.com/forum/topic/716/how-to-turn-my-windows-pc-on-using-wol</link><generator>RSS for Node</generator><lastBuildDate>Tue, 18 Aug 2026 02:39:57 GMT</lastBuildDate><atom:link href="https://www.triggercmd.com/forum/topic/716.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 29 May 2020 17:21:12 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to How to turn my WINDOWS pc on using wol? on Tue, 02 Jun 2020 00:21:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/marcelo-botelho" aria-label="Profile: Marcelo-Botelho">@<bdi>Marcelo-Botelho</bdi></a>, you don't need to use the computer_on_off.sh.  That's a complicated scenario, so you should not start there.</p>
<p dir="auto">You have two computers, and you're trying to use one computer to turn on the other computer, correct?</p>
<p dir="auto">My video shows me using a Raspberry Pi to turn on my Windows computer, but you don't have to use a Raspberry Pi.  If you have two Windows computers, you could use this utility instead:<br />
<a href="https://www.nirsoft.net/utils/wake_on_lan.html" rel="nofollow ugc">https://www.nirsoft.net/utils/wake_on_lan.html</a></p>
<p dir="auto">WakeMeOnLan.exe has a spanish version, and a GUI which can make it easy to test, then after you get that working, you can make a TRIGGERcmd command like this:</p>
<pre><code>c:\tools\WakeMeOnLan.exe /wakeup 40-65-81-A7-16-23
<p dir="auto">This assumes you copied the WakeMeOnLan.exe utility into t:\tools and 40-65-81-A7-16-23 is the mac address of the nic in the computer you're turning on.</p>
<p dir="auto">You can find the mac address by typing <strong>ipconfig /all</strong> on the computer you want to turn on.  You'll get output like this:</p>
<pre><code>Ethernet adapter Ethernet:
   Connection-specific DNS Suffix  . : lan
   Description . . . . . . . . . . . : Realtek PCIe GbE Family Controller
   Physical Address. . . . . . . . . : **C4-65-26-2A-93-97**
]]></description><link>https://www.triggercmd.com/forum/post/2299</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/2299</guid><dc:creator><![CDATA[Russ]]></dc:creator><pubDate>Tue, 02 Jun 2020 00:21:55 GMT</pubDate></item><item><title><![CDATA[Reply to How to turn my WINDOWS pc on using wol? on Mon, 01 Jun 2020 03:33:58 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/russ" aria-label="Profile: Russ">@<bdi>Russ</bdi></a>, I know you must be tired of explaining how to open windows through alexa until you record a video<br />
However, I am new to the programming world (I started because of your program) and I still have difficulty because of the language difference (until I try to translate your video through Google)</p>
<p dir="auto">I activated a Network Card Function in Bios, All right<br />
But at the time make the command I don't know how to proceed<br />
I Tried<br />
WakeOnLAN c8: 60: 00: 9b: 69: 1a (com meu endereço de rede)<br />
and<br />
/root/computer_on_off.sh<br />
.<br />
.<br />
Is Computer_on_off.sh a shortcut I need to take to trigger?</p>
<p dir="auto">If you teach me the step by step of the written command for me it’s easier to translate<br />
Thanks in advance for your patience</p>
]]></description><link>https://www.triggercmd.com/forum/post/2294</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/2294</guid><dc:creator><![CDATA[Marcelo Botelho]]></dc:creator><pubDate>Mon, 01 Jun 2020 03:33:58 GMT</pubDate></item><item><title><![CDATA[Reply to How to turn my WINDOWS pc on using wol? on Sat, 30 May 2020 00:08:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/raquel" aria-label="Profile: raquel">@<bdi>raquel</bdi></a>, have you seen this video yet?</p>
<p dir="auto"><a href="https://youtu.be/4M_4NhrHx0c" rel="nofollow ugc">https://youtu.be/4M_4NhrHx0c</a></p>
]]></description><link>https://www.triggercmd.com/forum/post/2261</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/2261</guid><dc:creator><![CDATA[Russ]]></dc:creator><pubDate>Sat, 30 May 2020 00:08:57 GMT</pubDate></item></channel></rss>
