<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[tcmd Go client:  Added support for a quoted string with spaces for the -params parameter.]]></title><description><![CDATA[<p dir="auto">Re: <a href="/forum/topic/196/tcmd-go-command-line-tool-is-available-now">tcmd GO command line tool is available now</a></p>
<p dir="auto">Download tcmd-windows-amd64.exe and rename it to tcmd.exe, and put it in a folder referenced in your PATH environment variable.  Then you can remotely run commands with multiple parameters like this:</p>
<pre><code>tcmd -computer russfam -trigger notepad -params "Deep Thoughts.txt"
<p dir="auto">That runs notepad on my family computer with the whole file name, including the space between Deep and Thoughts.txt:<br />
<img src="/forum/assets/uploads/files/1578769038482-ab32d878-e954-41d9-bf1d-0ab907c81ab0-image.png" alt="ab32d878-e954-41d9-bf1d-0ab907c81ab0-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Here's a video showing off the new feature:  <a href="https://youtu.be/q0Uu4SNFKFY" rel="nofollow ugc">https://youtu.be/q0Uu4SNFKFY</a></p>
]]></description><link>https://www.triggercmd.com/forum/topic/591/tcmd-go-client-added-support-for-a-quoted-string-with-spaces-for-the-params-parameter</link><generator>RSS for Node</generator><lastBuildDate>Sat, 14 Nov 2026 11:10:36 GMT</lastBuildDate><atom:link href="https://www.triggercmd.com/forum/topic/591.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 11 Jan 2020 18:33:52 GMT</pubDate><ttl>60</ttl></channel></rss>
