<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA["TRIGGERcmd Smart Home" Google Assistant action]]></title><description><![CDATA[<p dir="auto">Now you can say "Hey Google, turn on X" to run commands on your computers.</p>
<p dir="auto">This is great for X10 lights, or launching a program with <strong>on</strong> and closing it with <strong>off</strong>.</p>
<p dir="auto">If you set "Allow Parameters" to true, when you flip the command's virtual switch on or off, it will run your command with <strong>on</strong> or <strong>off</strong> as a parameter, or if you use the "Off Command" field, it will run that command when you say, "turn off X", and it will run the command in the "Command" field when you say "turn on X".</p>
<p dir="auto">You can also pass a color or a brightness number from 0 to 100 as a parameter to your script.  Just say what you'd say to change a light bulb's color or brightness.</p>
<p dir="auto">Here's a youtube video showing how it works:  <a href="https://youtu.be/jeiV5aySmTw" rel="nofollow ugc">https://youtu.be/jeiV5aySmTw</a></p>
<p dir="auto">To run commands in Google Assistant routines, use <a href="https://www.triggercmd.com/forum/topic/2551/error-with-google-routines">this method</a>.</p>
<p dir="auto">If you use voice match, and others in your household want to use a Google Home device trigger your commands, please <a href="https://www.triggercmd.com/forum/topic/526/now-you-can-share-your-computers-with-other-triggercmd-users">read this</a>.</p>
<p dir="auto"><strong>Steps to enable the TRIGGERcmd Smart Home Google Assistant action:</strong></p>
<li>
<p dir="auto">Open the Google Home app and tap the <strong>circle in the upper-right</strong>:<br />
<img src="https://triggercmdagents.s3.amazonaws.com/Pics/Forum/googleSmartHome/g1.png" alt="Google Home menu" class=" img-fluid img-markdown" /></p>
</li>
<li>
<p dir="auto">Select <strong>Assistant Settings</strong><br />
<img src="https://triggercmdagents.s3.amazonaws.com/Pics/Forum/googleSmartHome/g2.png" alt="Assistant settings" class=" img-fluid img-markdown" /></p>
</li>
<li>
<p dir="auto">Select the <strong>Assistant</strong> tab, and tap <strong>Home control</strong><br />
<img src="https://triggercmdagents.s3.amazonaws.com/Pics/Forum/googleSmartHome/g3.png" alt="Assistant tab Home Control" class=" img-fluid img-markdown" /></p>
</li>
<li>
<p dir="auto"><strong>Search</strong> for TRIGGERcmd Smart Home, and link your account.<br />
<img src="https://triggercmdagents.s3.amazonaws.com/Pics/Forum/googleSmartHome/g4.png" alt="Search TRIGGERcmd Smart Home" class=" img-fluid img-markdown" /></p>
</li>
<li>
<p dir="auto">Now you'll see your commands as switches you can turn on and off:<br />
<img src="https://triggercmdagents.s3.amazonaws.com/Pics/Forum/googleSmartHome/g5.png" alt="Devices" class=" img-fluid img-markdown" /></p>
</li>
]]></description><link>https://www.triggercmd.com/forum/topic/579/triggercmd-smart-home-google-assistant-action</link><generator>RSS for Node</generator><lastBuildDate>Sun, 15 Nov 2026 02:52:36 GMT</lastBuildDate><atom:link href="https://www.triggercmd.com/forum/topic/579.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 17 Dec 2019 16:36:37 GMT</pubDate><ttl>60</ttl></channel></rss>
