<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Using the Alexa Smart Home skill the first time]]></title><description><![CDATA[<p dir="auto">Click the appropriate Amazon link for your country below, then link your Amazon account to your TRIGGERcmd account.<br />
You'll be able to Discover your TRIGGERcmd commands as if they were smart home switches.<br />
Then you can say, "turn on calculator" to run calculator.</p>
<p dir="auto">Here's a video about how it works: <a href="https://www.youtube.com/watch?v=9Jm_s9sTZXw" rel="nofollow ugc">https://www.youtube.com/watch?v=9Jm_s9sTZXw</a></p>
<p dir="auto"><a href="https://www.amazon.com/dp/B07P1MMFRP" rel="nofollow ugc">United States</a><br />
<a href="https://www.amazon.com.br/VanderMey-Consulting-LLC-TRIGGERcmd-Smart/dp/B07P1MMFRP" rel="nofollow ugc">Brazil</a>  (<a href="https://www.youtube.com/watch?v=FTxIabp8CRg" rel="nofollow ugc">Portuguese video</a>)<br />
<a href="https://www.amazon.de/VanderMey-Consulting-LLC-TRIGGERcmd-Smart/dp/B07P1MMFRP" rel="nofollow ugc">Germany</a><br />
<a href="https://www.amazon.ca/VanderMey-Consulting-LLC-TRIGGERcmd-Smart/dp/B07P1MMFRP" rel="nofollow ugc">Canada</a><br />
<a href="https://www.amazon.com.au/VanderMey-Consulting-LLC-TRIGGERcmd-Smart/dp/B07P1MMFRP" rel="nofollow ugc">Australia</a><br />
<a href="https://www.amazon.fr/VanderMey-Consulting-LLC-TRIGGERcmd-Smart/dp/B07P1MMFRP" rel="nofollow ugc">France</a><br />
<a href="https://www.amazon.in/VanderMey-Consulting-LLC-TRIGGERcmd-Smart/dp/B07P1MMFRP" rel="nofollow ugc">India</a><br />
<a href="https://www.amazon.it/VanderMey-Consulting-LLC-TRIGGERcmd-Smart/dp/B07P1MMFRP" rel="nofollow ugc">Italy</a><br />
<a href="https://www.amazon.com.mx/VanderMey-Consulting-LLC-Inteligente-TRIGGERcmd/dp/B07P1MMFRP" rel="nofollow ugc">Mexico</a> (<a href="https://www.youtube.com/watch?v=Kd6Onta10cI" rel="nofollow ugc">Spanish video</a>)<br />
<a href="https://www.amazon.es/VanderMey-Consulting-LLC-Inteligente-TRIGGERcmd/dp/B07P1MMFRP" rel="nofollow ugc">Spain</a> (<a href="https://www.youtube.com/watch?v=8-Ba8j0k4gA" rel="nofollow ugc">Spanish video</a>)<br />
<a href="https://www.amazon.co.uk/VanderMey-Consulting-LLC-TRIGGERcmd-Smart/dp/B07P1MMFRP" rel="nofollow ugc">England</a><br />
<a href="https://www.amazon.co.jp/VanderMey-Consulting-LLC-TRIGGERcmd-Smart/dp/B07P1MMFRP" rel="nofollow ugc">Japan</a></p>
<p dir="auto">If you set "Allow Parameters" to true, when you flip the command's virtual switch on or off, it will run your command with <strong>on</strong> or <strong>off</strong> as a parameter, or if you use the "Off Command" field, it will run that command when you say, "turn off X", and it will run the command in the "Command" field when you say "turn on X".</p>
]]></description><link>https://www.triggercmd.com/forum/topic/538/using-the-alexa-smart-home-skill-the-first-time</link><generator>RSS for Node</generator><lastBuildDate>Thu, 08 Oct 2026 14:24:55 GMT</lastBuildDate><atom:link href="https://www.triggercmd.com/forum/topic/538.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 01 Nov 2019 01:27:31 GMT</pubDate><ttl>60</ttl></channel></rss>
