<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Turn PC on/off]]></title><description><![CDATA[<p dir="auto">Hi<br />
I have tried with gemini to get a solution but they could only help with the turn off. I would like to be able to turn my windows pc on/off using my google assistant please? I am not familiar with coding and writing scripts or even triggercmd. Any help would be greatly appreciated. Thanks</p>
]]></description><link>https://www.triggercmd.com/forum/topic/3341/turn-pc-on-off</link><generator>RSS for Node</generator><lastBuildDate>Sun, 13 Sep 2026 22:58:35 GMT</lastBuildDate><atom:link href="https://www.triggercmd.com/forum/topic/3341.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 01 Mar 2026 20:08:53 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Turn PC on/off on Tue, 03 Mar 2026 21:56:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/rodney-mathee" aria-label="Profile: Rodney-Mathee">@<bdi>Rodney-Mathee</bdi></a>, I'm glad you told me it's wifi, not wired ethernet.  That changes things.  For one, that WakeMeOnLan.exe tool from Nirsoft won't work because it doesn't support wireless networks.</p>
<p dir="auto">I've never tried "wake-on-wlan" but in theory it's possible with the right hardware.<br />
<a href="https://documentation.ubuntu.com/core/explanation/system-snaps/network-manager/how-to-guides/configure-the-snap/wake-on-wlan/" rel="nofollow ugc">https://documentation.ubuntu.com/core/explanation/system-snaps/network-manager/how-to-guides/configure-the-snap/wake-on-wlan/</a></p>
]]></description><link>https://www.triggercmd.com/forum/post/8867</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/8867</guid><dc:creator><![CDATA[Russ]]></dc:creator><pubDate>Tue, 03 Mar 2026 21:56:08 GMT</pubDate></item><item><title><![CDATA[Reply to Turn PC on/off on Mon, 02 Mar 2026 18:40:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/russ" aria-label="Profile: Russ">@<bdi>Russ</bdi></a> Thank you.<br />
So this what i have. A mini PC running detection for my darts setup. Then another mini PC running the funky stuff for the darts setup and a secondary monitor. The only reason i am doing this is because i cannot solder a second external power button onto the second pc. And it will be hidden so not easy to access. And the detection pc is running on Ubuntu. Dont know how much of an issue that will be if i wanted to use it too start the second pc.<br />
And all on WIFI</p>
]]></description><link>https://www.triggercmd.com/forum/post/8866</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/8866</guid><dc:creator><![CDATA[Rodney Mathee]]></dc:creator><pubDate>Mon, 02 Mar 2026 18:40:12 GMT</pubDate></item><item><title><![CDATA[Reply to Turn PC on/off on Sun, 01 Mar 2026 22:37:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/rodney-mathee" aria-label="Profile: Rodney-Mathee">@<bdi>Rodney-Mathee</bdi></a>, you'll need to use a separate computer on your network to turn it on via "Wake On Lan" and you'll probably need to enable it in the BIOS of the computer you want to turn on.</p>
<p dir="auto">This tool could send the "magic packet" to turn on the other computer on your network:<br />
<a href="https://www.nirsoft.net/utils/wake_on_lan.html" rel="nofollow ugc">https://www.nirsoft.net/utils/wake_on_lan.html</a></p>
<p dir="auto"><strong>The following is from the documentation page I linked to above</strong>:</p>
<p dir="auto">Turn On a Computer From Command-Line<br />
WakeMeOnLan allows you to wake up a computer on your network without displaying any user interface, by using the /wakeup command-line option. You can specify the computer name, IP address, or the free user text that you typed in the properties window, as long as the computer information is stored inside the .cfg file. You can also specify the MAC address of the remote network card, even if the computer is not stored in the .cfg file.<br />
Optionally, you can specify the port number in the second parameter, and broadcast address in the third parameter.</p>
<p dir="auto">Examples:<br />
WakeMeOnLan.exe /wakeup 192.168.1.25<br />
WakeMeOnLan.exe /wakeup Comp01<br />
WakeMeOnLan.exe /wakeup Comp02<br />
WakeMeOnLan.exe /wakeup 40-65-81-A7-16-23<br />
WakeMeOnLan.exe /wakeup 406581A71623<br />
WakeMeOnLan.exe /wakeup Comp02 30000 192.168.0.255<br />
WakeMeOnLan.exe /wakeup 192.168.1.25 20000 192.168.1.255</p>
<p dir="auto">You can also wake up all computers in the list by using /wakeupall command-line option. Like in the /wakeup command-line option, you can optionally specify broadcast address and port number.</p>
WakeMeOnLan.exe /wakeupall<br />
WakeMeOnLan.exe /wakeupall 20000 192.168.2.255 If you want to wake up all computers in specific IP addresses range, you can use /wakeupiprange command-line option</p>
WakeMeOnLan.exe /wakeupiprange 192.168.0.25 192.168.0.100<br />
WakeMeOnLan.exe /wakeupiprange 192.168.0.11 192.168.0.20 20000 192.168.0.255</p>
<p dir="auto">If you want to wakeup multiple computers, you can use /wakeupmulti command-line option.<br />
Examples:<br />
WakeMeOnLan.exe /wakeupmulti 192.168.1.19 192.168.1.55 192.168.1.82<br />
WakeMeOnLan.exe /wakeupmulti Comp01 Comp02</p>
]]></description><link>https://www.triggercmd.com/forum/post/8865</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/8865</guid><dc:creator><![CDATA[Russ]]></dc:creator><pubDate>Sun, 01 Mar 2026 22:37:38 GMT</pubDate></item></channel></rss>
