<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[sending parameter to a home assistant TCMD switch]]></title><description><![CDATA[<p dir="auto">Hi,<br />
I'm new here so please be gentle</p>
<p dir="auto">I sent up a simple curl command in TCMD (tigger cmd) .. litterally just 'curl' and set 'allow parameters'</p>
<p dir="auto">I now want to be able to send a paratameter to this from a switch or action in home assistant so i can send http request / web hook</p>
<p dir="auto">example parameter/webhook .. "http;<a href="//mywebkook.com/tokenblahblah" rel="nofollow ugc">//mywebkook.com/tokenblahblah</a>"</p>
<p dir="auto">example webhook trigger.. curl "http;<a href="//mywebkook.com/tokenblahblah" rel="nofollow ugc">//mywebkook.com/tokenblahblah</a>" would activate a simple webhook .. checked and works fine from cmd line</p>
<p dir="auto">any idea how to do this? Cheers everyone</p>
]]></description><link>https://www.triggercmd.com/forum/topic/3197/sending-parameter-to-a-home-assistant-tcmd-switch</link><generator>RSS for Node</generator><lastBuildDate>Sat, 18 Apr 2026 23:11:19 GMT</lastBuildDate><atom:link href="https://www.triggercmd.com/forum/topic/3197.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 03 Jan 2025 19:12:16 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to sending parameter to a home assistant TCMD switch on Sun, 19 Jan 2025 17:54:13 GMT]]></title><description><![CDATA[<p dir="auto">Thanks <a class="mention plugin-mentions-user plugin-mentions-a" href="https://www.triggercmd.com/forum/uid/18307">@metablast</a>.</p>
<p dir="auto">I've been thinking about how I could allow other parameters.  Would you want to create an HA automation that triggers the command, and do you want the properties of the device that triggered the automation to be selectable as command parameters?  I think I could build a way to do that.</p>
]]></description><link>https://www.triggercmd.com/forum/post/8445</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/8445</guid><dc:creator><![CDATA[Russ]]></dc:creator><pubDate>Sun, 19 Jan 2025 17:54:13 GMT</pubDate></item><item><title><![CDATA[Reply to sending parameter to a home assistant TCMD switch on Sat, 18 Jan 2025 18:53:10 GMT]]></title><description><![CDATA[<p dir="auto">Thanks for letting me know... when I say bot it was just mean that a post shifted automatically to give more info at the top about home assistant</p>
]]></description><link>https://www.triggercmd.com/forum/post/8444</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/8444</guid><dc:creator><![CDATA[metablast]]></dc:creator><pubDate>Sat, 18 Jan 2025 18:53:10 GMT</pubDate></item><item><title><![CDATA[Reply to sending parameter to a home assistant TCMD switch on Tue, 07 Jan 2025 13:05:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://www.triggercmd.com/forum/uid/18307">@metablast</a>, sorry, at this point in time the TRIGGERcmd Home Assistant integration only supports sending the <strong>on</strong> and <strong>off</strong> parameters with the trigger.</p>
<p dir="auto">You mentioned "Bot Replied."  What bot are you talking about?</p>
]]></description><link>https://www.triggercmd.com/forum/post/8426</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/8426</guid><dc:creator><![CDATA[Russ]]></dc:creator><pubDate>Tue, 07 Jan 2025 13:05:56 GMT</pubDate></item><item><title><![CDATA[Reply to sending parameter to a home assistant TCMD switch on Fri, 03 Jan 2025 19:20:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://www.triggercmd.com/forum/uid/18307">@metablast</a></p>
<p dir="auto">Bot Replied with rest commands avalible but if there is a more simple way to pass the parameter at the switch level that would be far better unless i am missing something.</p>
<p dir="auto">That way the parameter or webhook can be added directly into the switch or automation instead of more coding or TCMD commands for each webhook</p>
]]></description><link>https://www.triggercmd.com/forum/post/8422</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/8422</guid><dc:creator><![CDATA[metablast]]></dc:creator><pubDate>Fri, 03 Jan 2025 19:20:55 GMT</pubDate></item></channel></rss>
