<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Home Assistant Blueprints for TRIGGERcmd]]></title><description><![CDATA[<p dir="auto">Home Assistant Blueprint to run commands when motion is detected.</p>
<p dir="auto">Here's a <a href="https://youtu.be/HVvY-1yHrWM" rel="nofollow ugc">Youtube video</a> showing how it works.</p>
<p dir="auto"><img src="/forum/assets/uploads/files/1735684087907-5ba988cd-3033-4252-8674-7bfd8019943a-image.png" alt="5ba988cd-3033-4252-8674-7bfd8019943a-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Find this button in the lower-right of the Blueprints tab to import the blueprint:<br />
<img src="/forum/assets/uploads/files/1735684551062-44cc25f3-1fa8-4f88-a1f3-b5acb8f2a67c-image.png" alt="44cc25f3-1fa8-4f88-a1f3-b5acb8f2a67c-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">This is the blueprint address:<br />
<a href="https://github.com/rvmey/TRIGGERcmd-Agent/blob/master/ha_blueprints/motion_switch.yaml" rel="nofollow ugc">https://github.com/rvmey/TRIGGERcmd-Agent/blob/master/ha_blueprints/motion_switch.yaml</a></p>
<p dir="auto"><img src="/forum/assets/uploads/files/1735696316577-916b169a-8d97-4844-8673-cafbb8bc3ca8-image.png" alt="916b169a-8d97-4844-8673-cafbb8bc3ca8-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">I picked my camera's motion sensor, and the HA switch for my "DS Logger" command under "Choose entity" and now I get a log entry each time motion is detected because it triggers my logger script.<br />
<img src="/forum/assets/uploads/files/1735684457428-e05b36f6-3b02-4483-870c-d4e9d37e02be-image.png" alt="e05b36f6-3b02-4483-870c-d4e9d37e02be-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">I also made these simpler general purpose blueprints you can use with any entity that turns on or off, not just motion sensors.  You'll need both of you want to run the off command when the run when you turn the entity off, and the normal command when you turn it on.<br />
On: <a href="https://github.com/rvmey/TRIGGERcmd-Agent/blob/master/ha_blueprints/on_switch.yaml" rel="nofollow ugc">https://github.com/rvmey/TRIGGERcmd-Agent/blob/master/ha_blueprints/on_switch.yaml</a><br />
Off: <a href="https://github.com/rvmey/TRIGGERcmd-Agent/blob/master/ha_blueprints/off_switch.yaml" rel="nofollow ugc">https://github.com/rvmey/TRIGGERcmd-Agent/blob/master/ha_blueprints/off_switch.yaml</a></p>
]]></description><link>https://www.triggercmd.com/forum/topic/3192/home-assistant-blueprints-for-triggercmd</link><generator>RSS for Node</generator><lastBuildDate>Tue, 14 Jul 2026 20:01:56 GMT</lastBuildDate><atom:link href="https://www.triggercmd.com/forum/topic/3192.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 31 Dec 2024 22:33:22 GMT</pubDate><ttl>60</ttl></channel></rss>
