<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Need Advice on Setting Up Custom Commands for Multiple Devices]]></title><description><![CDATA[<p dir="auto">Hello there,</p>
<p dir="auto">I am fairly new to TRIGGERcmd and have been experimenting with setting up commands across multiple devices in my home network. I have had some success with basic commands on a single machine; but now I am looking to expand and manage commands across multiple devices, and I am a little stuck.</p>
<p dir="auto">Installed TRIGGERcmd on my Windows PC and successfully set up a couple of simple commands. Linked my account and tested triggering those commands from the web interface and mobile app it works great.</p>
<p dir="auto">Recently installed TRIGGERcmd on a Raspberry Pi to see if I could control it alongside my PC.</p>
<p dir="auto">When I add commands on the Raspberry Pi, they don’t seem to sync properly with my account. Is there something specific I need to configure to manage commands on multiple devices?</p>
<p dir="auto">Can I group commands by device or category in the interface to make it easier to find and organize them? For example, having a PC group and a Raspberry Pi group.</p>
<p dir="auto">Also, I have gone through this post; <a href="https://www.triggercmd.com/forum/topic/2407/central-server-to-send-commands-to-multiple-pcs">https://www.triggercmd.com/forum/topic/2407/</a><a href="https://www.igmguru.com/machine-learning-ai/rpa-uipath-certification-training" rel="nofollow ugc">uipath</a><a href="https://www.triggercmd.com/forum/topic/2407/central-server-to-send-commands-to-multiple-pcs">-server-to-send-commands-to-multiple-pcs</a> which definitely helped me out a lot.</p>
<p dir="auto">Is there a way to assign a custom trigger phrase to differentiate between devices when using voice assistants like Alexa or Google Assistant?</p>
<p dir="auto">Thanks in advance for your help and assistance.</p>
]]></description><link>https://www.triggercmd.com/forum/topic/3183/need-advice-on-setting-up-custom-commands-for-multiple-devices</link><generator>RSS for Node</generator><lastBuildDate>Fri, 12 Jun 2026 02:30:19 GMT</lastBuildDate><atom:link href="https://www.triggercmd.com/forum/topic/3183.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 16 Dec 2024 05:36:52 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Need Advice on Setting Up Custom Commands for Multiple Devices on Mon, 16 Dec 2024 13:22:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://www.triggercmd.com/forum/uid/24220">@davidcook</a>, let's focus on making commands sync with your Raspberry Pi first.</p>
<p dir="auto">Did you use <a href="https://www.triggercmd.com/forum/topic/12/raspberry-pi-setup">these instructions</a> when you setup your Raspberry Pi?</p>
<p dir="auto">If you install the background service with this command:</p>
<pre><code>/usr/share/triggercmdagent/app/src/installdaemon.sh
<p dir="auto">... it runs as root, and reads /root/.TRIGGERcmdData/commands.json, and it will only sync your background commands (ground = background) not foreground commands.</p>
<p dir="auto">If you're editing your /home/pi/.TRIGGERcmdData/commands.json that could be the problem.</p>
<p dir="auto">Please show me the output of this command:  <strong>systemctl status triggercmdagent</strong><br />
I'd like to confirm it's running.</p>
<p dir="auto">Also, do you see the your Raspberry Pi listed on your "<a href="https://www.triggercmd.com/user/computer/list" rel="nofollow ugc">Your Computers</a>" page?  If not, maybe it didn't create a computer because you're not subscribed.  You can only have one computer if you're not subscribed.</p>
]]></description><link>https://www.triggercmd.com/forum/post/8385</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/8385</guid><dc:creator><![CDATA[Russ]]></dc:creator><pubDate>Mon, 16 Dec 2024 13:22:45 GMT</pubDate></item></channel></rss>
