<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Update Agent Triggered Antivirus (Bitdefender)]]></title><description><![CDATA[<p dir="auto">W10 64 fully patched with BitDefender</p>
<p dir="auto">Hi there!</p>
<p dir="auto">I used the Update Agent option and it triggered the antivirus (that quarantined TriggerCMD).</p>
<p dir="auto">Even after restoring from quarantine, it stopped working (I think that the restore option from the AV didn't work). Shortcut also missing the target executable.</p>
<p dir="auto">Trying uninstalling it and installing again, no joy (install fails).</p>
<p dir="auto">The dialog has an open log for details option, but the file opened (%user%\AppData\Local\SquirrelTemp\SquirrelSetup.log) h as no new logs (last timestamp is from 2023-07-13.</p>
<p dir="auto">Any ideas?</p>
<p dir="auto">thanks in advance!</p>
]]></description><link>https://www.triggercmd.com/forum/topic/2784/update-agent-triggered-antivirus-bitdefender</link><generator>RSS for Node</generator><lastBuildDate>Tue, 16 Jun 2026 22:04:00 GMT</lastBuildDate><atom:link href="https://www.triggercmd.com/forum/topic/2784.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 04 Jan 2024 11:55:59 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Update Agent Triggered Antivirus (Bitdefender) on Thu, 04 Jan 2024 17:27:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://www.triggercmd.com/forum/uid/21964">@StealthNet</a>, yes, good idea.  To avoid that problem when you update next time you could exclude those two folders.</p>
]]></description><link>https://www.triggercmd.com/forum/post/7626</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/7626</guid><dc:creator><![CDATA[Russ]]></dc:creator><pubDate>Thu, 04 Jan 2024 17:27:43 GMT</pubDate></item><item><title><![CDATA[Reply to Update Agent Triggered Antivirus (Bitdefender) on Thu, 04 Jan 2024 14:08:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://www.triggercmd.com/forum/uid/1">@Russ</a> it worked! Thank you!</p>
<p dir="auto">Any path suggestions to exclude from AV?</p>
]]></description><link>https://www.triggercmd.com/forum/post/7625</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/7625</guid><dc:creator><![CDATA[StealthNet]]></dc:creator><pubDate>Thu, 04 Jan 2024 14:08:57 GMT</pubDate></item><item><title><![CDATA[Reply to Update Agent Triggered Antivirus (Bitdefender) on Thu, 04 Jan 2024 13:15:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://www.triggercmd.com/forum/uid/21964">@StealthNet</a> , your commands and other configuration are safe.  When you uninstall, those remain in %USERPROFILE%\.TRIGGERcmdData.</p>
<p dir="auto">I suggest you try this:</p>
<ol>
<li>Temporarily disable BitDefender.</li>
<li>Uninstall TRIGGERcmd Agent.</li>
<li>Delete %USERPROFILE%\AppData\Local\TRIGGERcmdAgent</li>
<li>Reinstall TRIGGERcmd Agent.</li>
<li>Re-enable BitDefender.</li>
</ol>
<p dir="auto">My theory is the old files in %USERPROFILE%\AppData\Local\TRIGGERcmdAgent are getting in the way, so deleting those would help.</p>
]]></description><link>https://www.triggercmd.com/forum/post/7624</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/7624</guid><dc:creator><![CDATA[Russ]]></dc:creator><pubDate>Thu, 04 Jan 2024 13:15:26 GMT</pubDate></item></channel></rss>
