<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Problem with the triggers in Alexa]]></title><description><![CDATA[<p dir="auto">I have a problem with the triggers in Alexa, only the old ones appear, the new ones don't appear.<br />
I have installed the latest version on my PCs. In Alexa I have installed TRIGGERcmd Smart Home.<br />
I have deactivated and reactivated the skill account. But they still do not appear. I have tried on another smarphone in case this is the issue, but the issue is the same.</p>
<p dir="auto">I don't know what the issue could be.</p>
]]></description><link>https://www.triggercmd.com/forum/topic/2738/problem-with-the-triggers-in-alexa</link><generator>RSS for Node</generator><lastBuildDate>Sun, 10 May 2026 17:06:07 GMT</lastBuildDate><atom:link href="https://www.triggercmd.com/forum/topic/2738.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 03 Nov 2023 12:59:29 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Problem with the triggers in Alexa on Sat, 04 Nov 2023 12:52:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://www.triggercmd.com/forum/uid/2682">@fcovalls</a>, please check/try these things:</p>
<li>Make sure each computer has a unique <strong>Voice Name</strong> value or is your default computer.</li>
<li>Make sure each command has a <strong>Voice</strong> field set.</li>
<li>If you have one computer that's misbehaving, try renaming it and renaming it back.  That will force Alexa to re-create the devices.</li>
<li>Try changing your default computer from your profile page.</li>
<li>Confirm you see the <a href="https://www.triggercmd.com/user/command/shprintlist" rel="nofollow ugc">Smart Home Voice Commands</a> page to make sure you see it there.  If you don't see it there, Alexa won't create a device for it, so troubleshoot that first.</li>
]]></description><link>https://www.triggercmd.com/forum/post/7497</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/7497</guid><dc:creator><![CDATA[Russ]]></dc:creator><pubDate>Sat, 04 Nov 2023 12:52:00 GMT</pubDate></item></channel></rss>
