<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Execute IFTTT in windows]]></title><description><![CDATA[<p dir="auto">I need a command to execute IFTTT in windows, with Triggercmd. I want a way to execute ifttt inside a command in Triggercmd</p>
]]></description><link>https://www.triggercmd.com/forum/topic/2689/execute-ifttt-in-windows</link><generator>RSS for Node</generator><lastBuildDate>Sun, 12 Apr 2026 12:36:39 GMT</lastBuildDate><atom:link href="https://www.triggercmd.com/forum/topic/2689.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 30 Aug 2023 23:11:13 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Execute IFTTT in windows on Fri, 01 Sep 2023 12:06:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://www.triggercmd.com/forum/uid/21020">@Mauro</a>, <a class="mention plugin-mentions-user plugin-mentions-a" href="https://www.triggercmd.com/forum/uid/3234">@Matt-Packwood</a>'s solution would work, but here's another option.  You could create an IFTTT applet with TRIGGERcmd as the THIS part.  Pick <strong>Specific command</strong> and choose one of your TRIGGERcmd commands.  It doesn't matter what it does because all you care about is the fact that it will run your IFTTT applet.</p>
<p dir="auto">This is a built-in function of the TRIGGERcmd IFTTT integration:</p>
<p dir="auto"><img src="/forum/assets/uploads/files/1693569627220-f53b5c93-57ec-48dc-82de-cab91ff289c9-image.png" alt="f53b5c93-57ec-48dc-82de-cab91ff289c9-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Then, if you want to run a command on your Windows PC that will trigger that TRIGGERcmd command that will start the IFTTT applet, you could run that TRIGGERcmd command using the <a href="https://docs.triggercmd.com/#/./tcmdCLI" rel="nofollow ugc">tcmd command line tool</a>.</p>
]]></description><link>https://www.triggercmd.com/forum/post/7335</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/7335</guid><dc:creator><![CDATA[Russ]]></dc:creator><pubDate>Fri, 01 Sep 2023 12:06:32 GMT</pubDate></item><item><title><![CDATA[Reply to Execute IFTTT in windows on Thu, 31 Aug 2023 10:41:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://www.triggercmd.com/forum/uid/21020">@Mauro</a> I am unsure what you are asking, are you looking to "trigger an IFTTT recipe from TriggerCMD"?<br />
You could make a "curl" call to the IFTTT webhook.</p>
]]></description><link>https://www.triggercmd.com/forum/post/7333</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/7333</guid><dc:creator><![CDATA[Matt Packwood]]></dc:creator><pubDate>Thu, 31 Aug 2023 10:41:16 GMT</pubDate></item></channel></rss>
