<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Change computer]]></title><description><![CDATA[<p dir="auto">While waiting for the delivery of the pieces for a new PC (let's call it PC A) I setup an account temporarily using another PC (let's call it PC <img src="https://www.triggercmd.com/forum/assets/plugins/nodebb-plugin-emoji/emoji/emoji-one/1f60e.png?v=6sa9akdcpc2" class="not-responsive emoji emoji-emoji-one emoji--smiling_face_with_sunglasses" style="height:23px;width:auto;vertical-align:middle" title="B)" alt="😎" /> and created a few triggers.</p>
<p dir="auto">Now the PC A is up and running: can I swap PC without loosing the triggers I have already created?<br />
If yes, how?<br />
Thanks.<br />
fabio</p>
]]></description><link>https://www.triggercmd.com/forum/topic/2578/change-computer</link><generator>RSS for Node</generator><lastBuildDate>Sun, 10 May 2026 17:08:05 GMT</lastBuildDate><atom:link href="https://www.triggercmd.com/forum/topic/2578.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 29 Mar 2023 20:31:51 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Change computer on Wed, 27 Mar 2024 17:13:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://www.triggercmd.com/forum/uid/1">@Russ</a> so the short URLs act as a redirect.   Thanks Russ.</p>
]]></description><link>https://www.triggercmd.com/forum/post/7771</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/7771</guid><dc:creator><![CDATA[Smart Communities]]></dc:creator><pubDate>Wed, 27 Mar 2024 17:13:55 GMT</pubDate></item><item><title><![CDATA[Reply to Change computer on Wed, 27 Mar 2024 12:47:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://www.triggercmd.com/forum/uid/2022">@Smart-Communities</a>, if you give the new device the same computer name, the short bookmarks should still work.  They specify a computer name and trigger name.</p>
<p dir="auto">Normal bookmarks specify the trigger ID so those stop working if you even change certain fields in the trigger, like the name because that deletes and recreates the trigger with a new ID.</p>
]]></description><link>https://www.triggercmd.com/forum/post/7770</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/7770</guid><dc:creator><![CDATA[Russ]]></dc:creator><pubDate>Wed, 27 Mar 2024 12:47:45 GMT</pubDate></item><item><title><![CDATA[Reply to Change computer on Tue, 26 Mar 2024 13:58:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://www.triggercmd.com/forum/uid/1">@Russ</a> Does this keep the same URLs for triggering?  If not, is that possible?</p>
<p dir="auto">For instance, I have a few people with OBS configurations that send triggers to a specific PC.  If the PC had to be replaced it would be ideal to use the same bookmark URLs on the new device.</p>
]]></description><link>https://www.triggercmd.com/forum/post/7769</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/7769</guid><dc:creator><![CDATA[Smart Communities]]></dc:creator><pubDate>Tue, 26 Mar 2024 13:58:40 GMT</pubDate></item><item><title><![CDATA[Reply to Change computer on Thu, 30 Mar 2023 12:34:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://www.triggercmd.com/forum/uid/18410">@prik-m</a>, to transfer your commands to the other computer, you have to copy your commands.json file over to it.  That's where they're defined.  It's in c:\Users\(your user)\.TRIGGERcmdData.  You could also use the Text Command Editor to edit commands.json and just copy/paste the text.</p>
]]></description><link>https://www.triggercmd.com/forum/post/6924</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/6924</guid><dc:creator><![CDATA[Russ]]></dc:creator><pubDate>Thu, 30 Mar 2023 12:34:24 GMT</pubDate></item></channel></rss>
