<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Turn Monitor Off doesnt work with Alexa]]></title><description><![CDATA[<p dir="auto">Re: <a href="/forum/topic/280/turn-computer-monitors-off">Turn Computer Monitors Off</a></p>
<p dir="auto">When I click run the command in current commands the monitor does turn off, but when I tell Alexa to turn it off, she says "ok" but doesn't turn off the monitor. On Windows.</p>
]]></description><link>https://www.triggercmd.com/forum/topic/1992/turn-monitor-off-doesnt-work-with-alexa</link><generator>RSS for Node</generator><lastBuildDate>Tue, 18 Aug 2026 02:48:20 GMT</lastBuildDate><atom:link href="https://www.triggercmd.com/forum/topic/1992.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 21 Jan 2022 18:04:21 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Turn Monitor Off doesnt work with Alexa on Fri, 20 Oct 2023 21:55:58 GMT]]></title><description><![CDATA[<p dir="auto">@David-0, this command works for me on my Windows 11 box:</p>
<pre><code>nircmd monitor off
<p dir="auto">These are the relevant docs for that nircmd function:<br />
<a href="https://nircmd.nirsoft.net/monitor.html" rel="nofollow ugc">https://nircmd.nirsoft.net/monitor.html</a></p>
<p dir="auto">You could also consider this command:</p>
<pre><code>MultiMonitorTool.exe /TurnOff 2
<p dir="auto">You'll need to make sure nircmd.exe or MultiMonitorTool.exe is in a folder referenced in your PATH environment variable.  I just talked about that with <a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/h6477801471" aria-label="Profile: h6477801471">@<bdi>h6477801471</bdi></a> here:<br />
<a href="https://www.triggercmd.com/forum/topic/2725/monitor-control-command-issue/2">https://www.triggercmd.com/forum/topic/2725/monitor-control-command-issue/2</a></p>
]]></description><link>https://www.triggercmd.com/forum/post/7449</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/7449</guid><dc:creator><![CDATA[Russ]]></dc:creator><pubDate>Fri, 20 Oct 2023 21:55:58 GMT</pubDate></item><item><title><![CDATA[Reply to Turn Monitor Off doesnt work with Alexa on Fri, 20 Oct 2023 19:44:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/ricardomat" aria-label="Profile: ricardomat">@<bdi>ricardomat</bdi></a> Which command do you use pls? Looking for a working one. thnx</p>
]]></description><link>https://www.triggercmd.com/forum/post/7448</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/7448</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Fri, 20 Oct 2023 19:44:26 GMT</pubDate></item><item><title><![CDATA[Reply to Turn Monitor Off doesnt work with Alexa on Fri, 21 Jan 2022 19:32:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/ricardomat" aria-label="Profile: ricardomat">@<bdi>ricardomat</bdi></a> does it work if you click the green Trigger button on the website?</p>
]]></description><link>https://www.triggercmd.com/forum/post/5335</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/5335</guid><dc:creator><![CDATA[Russ]]></dc:creator><pubDate>Fri, 21 Jan 2022 19:32:16 GMT</pubDate></item></channel></rss>
