<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Run an Alexa routine when a command runs]]></title><description><![CDATA[<p dir="auto">You've always been able to run a command from an Alexa routine, but now you can run an Alexa routine when your command runs.</p>
<p dir="auto">Here are the steps:</p>
<li>Enable the <a href="https://www.amazon.com/VanderMey-Consulting-LLC-TRIGGERcmd-Smart/dp/B07P1MMFRP" rel="nofollow ugc">TRIGGERcmd Smart Home Alexa skill</a></li>
<li>Create an Alexa routine</li>
<li>Select <strong>When this happens</strong></li>
<li>Select <strong>Smart Home</strong></li>
<li>Select your command.</li>
<li>Select SAVE</li>
<p dir="auto">Here's a <a href="https://www.youtube.com/watch?v=nrqj-OwDpGE" rel="nofollow ugc">YouTube video</a> showing how it works.</p>
]]></description><link>https://www.triggercmd.com/forum/topic/1844/run-an-alexa-routine-when-a-command-runs</link><generator>RSS for Node</generator><lastBuildDate>Thu, 21 May 2026 08:20:08 GMT</lastBuildDate><atom:link href="https://www.triggercmd.com/forum/topic/1844.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 30 Nov 2021 03:03:19 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Run an Alexa routine when a command runs on Sun, 30 Oct 2022 00:10:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://www.triggercmd.com/forum/uid/10529">@esaltat</a>, good idea!  Thanks for posting your use-case.</p>
<p dir="auto">EDIT:  FYI, to do what esaltat is talking about, you have your Alexa routine run a command that uses the <a href="https://www.triggercmd.com/forum/topic/341/voice-reply-field-now-allows-placeholders-for-trigger-computer-and-params">Voice Reply</a> field.  The routine runs it via one of the 2 legacy Alexa skills called TRIGGERcmd or TRIGGER command.  Alexa routines use those skills via the <strong>custom</strong> action that effectively has Alexa say to herself, "Alexa, ask TRIGGER C M D to run calculator."  Substitute the word "calculator" for your command's voice word of course.</p>
]]></description><link>https://www.triggercmd.com/forum/post/4926</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/4926</guid><dc:creator><![CDATA[Russ]]></dc:creator><pubDate>Sun, 30 Oct 2022 00:10:34 GMT</pubDate></item><item><title><![CDATA[Reply to Run an Alexa routine when a command runs on Tue, 30 Nov 2021 22:53:33 GMT]]></title><description><![CDATA[<p dir="auto">This is a game changer! I'm now able to create a custom response using Alexa routine. Thank you for the update!</p>
]]></description><link>https://www.triggercmd.com/forum/post/4924</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/4924</guid><dc:creator><![CDATA[esaltat]]></dc:creator><pubDate>Tue, 30 Nov 2021 22:53:33 GMT</pubDate></item></channel></rss>
