<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Homebridge plugin]]></title><description><![CDATA[<p dir="auto">I couldn't find any homebridge plugin for triggerCMD. Does it exists? If it doesnt, will it be created?</p>
]]></description><link>https://www.triggercmd.com/forum/topic/1458/homebridge-plugin</link><generator>RSS for Node</generator><lastBuildDate>Sun, 10 May 2026 17:11:37 GMT</lastBuildDate><atom:link href="https://www.triggercmd.com/forum/topic/1458.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 07 Jul 2021 15:26:20 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Homebridge plugin on Sun, 10 May 2026 01:18:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://www.triggercmd.com/forum/uid/5224">@Beto-Gontijo</a>, you can use the <strong>homebridge-http-switch</strong> plugin with a configuration like this.  Click the red Bookmark button for the command you want to run, then copy the bookmark URL for the <strong>onUrl</strong> setting.  I recommend a "Short Bookmark" for this use-case because unlike the original Bookmark URL's, they persist, even when you make changes to your commands.  You can also change short bookmarks to a different computer/command combo in the <a href="http://triggercmd.com" rel="nofollow ugc">triggercmd.com</a> site UI, so you don't have to update the bookmark URL in the homebridge-http-switch config.</p>
<p dir="auto"><img src="/forum/assets/uploads/files/1625784860468-34a74b9b-a1ce-4b77-bba7-e63724b4e4b3-image.png" alt="34a74b9b-a1ce-4b77-bba7-e63724b4e4b3-image.png" class=" img-fluid img-markdown" /></p>
<pre><code>{
    "accessory": "HTTP-SWITCH",
    "name": "TRIGGERcmd - Calculator",
    "switchType": "stateless",
    "timeout": 500,
    "onUrl": "https://triggercmd.com/sb?b=blahblah"
<p dir="auto"><img src="/forum/assets/uploads/files/1625784709070-a461eacc-6e74-4c12-9e20-245ddc790878-image.png" alt="a461eacc-6e74-4c12-9e20-245ddc790878-image.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://www.triggercmd.com/forum/post/4250</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/4250</guid><dc:creator><![CDATA[Russ]]></dc:creator><pubDate>Sun, 10 May 2026 01:18:48 GMT</pubDate></item><item><title><![CDATA[Reply to Homebridge plugin on Wed, 07 Jul 2021 23:21:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://www.triggercmd.com/forum/uid/5224">@Beto-Gontijo</a>, I haven't used Homebridge yet, but I'll look into it.</p>
]]></description><link>https://www.triggercmd.com/forum/post/4242</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/4242</guid><dc:creator><![CDATA[Russ]]></dc:creator><pubDate>Wed, 07 Jul 2021 23:21:36 GMT</pubDate></item></channel></rss>
