<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Alexa not saying voice reply]]></title><description><![CDATA[<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/russ" aria-label="Profile: Russ">@<bdi>Russ</bdi></a>,</p>
<p dir="auto">I'm trying to get alexa to pronounce a voice reply after she executes a command, not having much luck:)</p>
<p dir="auto">I've got the following command on my raspberry pi:</p>
<p dir="auto">{"trigger":"Heating","command":"/home/pi/triggercmd/heating.sh","ground":"background","voice":"heating","voiceReply":"{{result}}","allowParams": "true"}</p>
<p dir="auto">I've updated my <a href="http://heating.sh" rel="nofollow ugc">heating.sh</a> script to run <a href="http://sendresult.sh" rel="nofollow ugc">sendresult.sh</a> and return an appropriate result, and I can see the result has been sent successfully in the triggercmd run list.  The result is sent well within the 5 second limit.</p>
<p dir="auto">Alexa doesn't say anything though after executing the command.</p>
<p dir="auto">Any ideas?</p>
<p dir="auto">Cheers,<br />
Dave.</p>
]]></description><link>https://www.triggercmd.com/forum/topic/1013/alexa-not-saying-voice-reply</link><generator>RSS for Node</generator><lastBuildDate>Tue, 13 Oct 2026 12:57:29 GMT</lastBuildDate><atom:link href="https://www.triggercmd.com/forum/topic/1013.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 07 Nov 2020 08:46:33 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Alexa not saying voice reply on Sat, 07 Nov 2020 21:47:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/dave-johnson" aria-label="Profile: Dave-Johnson">@<bdi>Dave-Johnson</bdi></a>, that's correct - the Smart Home version does a better job of matching what you say with your commands because Amazon has a list of your commands ahead of time, but unfortunately it can't support that Voice Reply feature.</p>
]]></description><link>https://www.triggercmd.com/forum/post/3138</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/3138</guid><dc:creator><![CDATA[Russ]]></dc:creator><pubDate>Sat, 07 Nov 2020 21:47:11 GMT</pubDate></item><item><title><![CDATA[Reply to Alexa not saying voice reply on Sat, 07 Nov 2020 19:50:14 GMT]]></title><description><![CDATA[<p dir="auto">Thanks for the reply Russ. I'm using the smart home version, I take it voice replies aren't supported by this?<br />
I'll give the other version a go!<br />
Cheers,<br />
Dave</p>
]]></description><link>https://www.triggercmd.com/forum/post/3137</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/3137</guid><dc:creator><![CDATA[Dave Johnson]]></dc:creator><pubDate>Sat, 07 Nov 2020 19:50:14 GMT</pubDate></item><item><title><![CDATA[Reply to Alexa not saying voice reply on Sat, 07 Nov 2020 17:11:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/dave-johnson" aria-label="Profile: Dave-Johnson">@<bdi>Dave-Johnson</bdi></a>, please confirm you're using the <a href="https://www.amazon.com/gp/product/B06XFN2TZN" rel="nofollow ugc">original Alexa skill</a>, not the Smart Home version.</p>
<p dir="auto">I just tested it using <a href="https://www.amazon.com/gp/product/B06XFN2TZN" rel="nofollow ugc">this skill</a> by saying, Alexa, ask TRIGGERcmd to run result.</p>
<p dir="auto">And I heard Alexa say, "result is 19."</p>
<p dir="auto">This is my command entry:</p>
<pre><code> {
  "trigger": "result",
  "command": "python d:\\result.py",
  "offCommand": "",
  "ground": "foreground",
  "voice": "result",
  "voiceReply": "result is {{result}}",
  "allowParams": "false"
<p dir="auto">This is my python script:</p>
<pre><code>import os
result = 'Nineteen'
sts = os.system(os.environ['USERPROFILE'] + "\\.TRIGGERcmdData\\SendResult.bat "+str(result))
]]></description><link>https://www.triggercmd.com/forum/post/3133</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/3133</guid><dc:creator><![CDATA[Russ]]></dc:creator><pubDate>Sat, 07 Nov 2020 17:11:58 GMT</pubDate></item></channel></rss>
